Hi everyone,
Bit of Noob here so be gentle. I’ve successfully added a BME280 temperature, humidity and pressure sensor to HA. The temperature readings are too high so I added (as per the guide in HA here the following line to the configuration.yaml file:
sensor
- platform: bme280
delta_temperature: -2.5
This brings the temperature reading into line with other thermometers, but also seems to have done the same with my pressure readings:
I can’t see how this could happen. There’s a double step change in the above graph as I made another deta_temperature change to see what would happen, and as you can see it stepped down with a D-temp of -3.5, and jumped up when I changed it to -2.5. Very strange!
Any ideas on how to limit the change to temperature readings or is this a limitation of the BME board?
Thanks in advance,
Paul.
