im running this code on a wemos d1 but the altitude goes from -50 to 130+.
The chips is mounted stationary on the wall so it most definatly is not moving.
esphome:
platform: ESP8266
board: d1_mini_pro
wifi:
ssid: "xxxxxxx"
password: "xxxxxx"
ap:
ssid: "Outside Temperature"
password: "nlOrd0eKRCJY"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "xxxx"
ota:
password: "xxxx"
i2c:
# sda: 21
# scl: 22
scan: True
- platform: bme280
temperature:
name: "BME280 Temperature"
oversampling: 16x
pressure:
name: "BME280 Pressure"
humidity:
name: "BME280 Relative Humidity"
address: 0x76
update_interval: 15s
lambda: |-
const float STANDARD_SEA_LEVEL_PRESSURE = 1032; //in hPa, see note
return ((id(bme280_temperature).state + 273.15) / 0.0065) *
(powf((STANDARD_SEA_LEVEL_PRESSURE / id(bme280_pressure).state), 0.190234) - 1); // in meter
icon: 'mdi:signal'
unit_of_measurement: 'm'
Any way to fix this behavior?
