I have several adafruit sensors using stemma qt connectors. As soon as I connect the bme I start to get
INFO 192.168.0.131: Unexpected error while reading incoming messages: 0 bytes read on a total of 1 expected bytes
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 505, in run_forever
await self._run_once()
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 480, in _run_once
pkt = await self._frame_helper.read_packet()
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 219, in read_packet
return await self._read_packet_plaintext()
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 197, in _read_packet_plaintext
preamble = await self._reader.readexactly(1)
File "/usr/lib/python3.9/asyncio/streams.py", line 721, in readexactly
raise exceptions.IncompleteReadError(incomplete, n)
asyncio.exceptions.IncompleteReadError: 0 bytes read on a total of 1 expected bytes
INFO Disconnected from ESPHome API for 192.168.0.131
WARNING Disconnected from API
INFO Successfully connected to 192.168.0.131
I have a CCS811 and a TSL2591 that I can connect to the same line and they work fine, the BME whether alone or daisy chained with the rest causes disconnects.
i2c:
scl: GPIO5
sda: GPIO4
# frequency: 100kHz
bme680_bsec:
address: 0x77
binary_sensor:
- platform: status
#wifi
- platform: wifi_signal
update_interval: 30s
- platform: bme680_bsec
temperature:
name: "Bosch Temperature"
sample_rate: ulp
pressure:
name: "Bosch Pressure"
sample_rate: ulp
humidity:
name: "Bosch Humidity"
sample_rate: lp
force_update: true
# iaq:
# name: "Bosch IAQ"
co2_equivalent:
name: "Bosch CO2 Equivalent"
breath_voc_equivalent:
name: "Bosch Breath VOC Equivalent"
gas_resistance:
name: "Bosch Gas Resistance"
- platform: ccs811
eco2:
tvoc:
address: 0x5A
# baseline: 0x66BE
update_interval: 20s
temperature: temperature
humidity: humidity
- platform: tsl2591
address: 0x29
update_interval: 10s
integration_time: 600ms
gain: low
visible:
name: "laq visible light"
infrared:
name: "laq infrared light"
full_spectrum:
name: "laq full spectrum light"
calculated_lux:
text_sensor:
iaq_accuracy:
name: "BME680 IAQ Accuracy"
switch:
- platform: restart
Error with before and after activity
[12:37:31][V][bme680_bsec.sensor:180]: Performing sensor run
[12:37:31][VV][i2c:056]: Beginning Transmission to 0x77:
[12:37:31][VV][i2c:093]: Writing 0b01011010 (0x5A)
[12:37:31][VV][i2c:093]: Writing 0b01100111 (0x67)
[12:37:31][VV][i2c:093]: Writing 0b01100100 (0x64)
[12:37:33][VV][scheduler:151]: Running interval 'tsl2591_interval_for_update' with interval=100 last_execution=239736 (now=239836)
[12:37:33][VV][i2c:056]: Beginning Transmission to 0x29:
[12:37:33][VV][i2c:093]: Writing 0b10110011 (0xB3)
[12:37:33][VV][i2c:061]: Transmission ended. Status code: 0x00
[12:37:34][V][bme680_bsec.sensor:180]: Performing sensor run
[12:37:34][VV][i2c:056]: Beginning Transmission to 0x77:
[12:37:34][VV][i2c:093]: Writing 0b01011010 (0x5A)
[12:37:34][VV][i2c:093]: Writing 0b01100111 (0x67)
[12:37:34][VV][i2c:093]: Writing 0b01100100 (0x64)
[12:37:36][VV][scheduler:151]: Running timeout 'read' with interval=208 last_execution=242749 (now=242964)
[12:37:36][V][bme680_bsec.sensor:223]: Reading data
[12:37:36][VV][i2c:056]: Beginning Transmission to 0x77:
[12:37:36][VV][i2c:093]: Writing 0b01110100 (0x74)
[12:37:36][VV][i2c:061]: Transmission ended. Status code: 0x00
