The code has not changed since it was working but, I have upgraded to esphome 2024.9.1 it still recognises that the BMP280 is there during bus scan but won’t read the temperature and pressure anymore. I connected the BMP280 to an Arduino and tested it - works fine so not a problem with the sensor.
substitutions:
friendly_name: av-cupboard-sensor
esphome:
friendly_name: ${friendly_name}
project:
version: dev
esp8266:
board: nodemcuv2
framework:
version: recommended
logger:
api:
encryption:
key: !secret api_av_cupboard_sensor
ota:
platform: esphome
password: !secret ota_av_cupboard_sensor
wifi:
ssid: !secret wifi_ssid
ap: {}
captive_portal:
web_server:
port: 80
i2c:
sda: GPIO4
scl: GPIO5
scan: true
platform: bmp280_i2c
i2c_id: bus_a
address: 0x76
temperature:
name: “AV cupboard temperature”
oversampling: 16x
pressure:
name: “AV cupboard pressure”
update_interval: 60s
Logs look good but I get no data back or from visiting it’s local web site!
[17:49:27][I][app:100]: ESPHome version 2024.9.1 compiled on Sep 28 2024, 17:06:37
[17:49:27][I][app:102]: Project esphome.web version dev
[17:49:27][C][wifi:600]: WiFi:
[17:49:27][C][wifi:428]: Local MAC: xx:xx:xx:xx:xx:xx
[17:49:27][C][wifi:433]: SSID: [redacted]
[17:49:27][C][wifi:436]: IP Address: x.x.x.x
[17:49:27][C][wifi:439]: BSSID: [redacted]
[17:49:27][C][wifi:441]: Hostname: ‘av-cupboard-temperature-sensor’
[17:49:27][C][wifi:443]: Signal strength: -52 dB ▂▄▆█
[17:49:27][C][wifi:447]: Channel: 11
[17:49:27][C][wifi:448]: Subnet: 255.255.255.0
[17:49:27][C][wifi:449]: Gateway: x.x.x.x
[17:49:27][C][wifi:450]: DNS1: 1.1.1.1
[17:49:27][C][wifi:451]: DNS2: 8.8.8.8
[17:49:27][C][logger:185]: Logger:
[17:49:27][C][logger:186]: Level: DEBUG
[17:49:27][C][logger:188]: Log Baud Rate: 115200
[17:49:27][C][logger:189]: Hardware UART: UART0
[17:49:27][C][i2c.arduino:071]: I2C Bus:
[17:49:27][C][i2c.arduino:072]: SDA Pin: GPIO4
[17:49:27][C][i2c.arduino:073]: SCL Pin: GPIO5
[17:49:27][C][i2c.arduino:074]: Frequency: 50000 Hz
[17:49:27][C][i2c.arduino:086]: Recovery: bus successfully recovered
[17:49:27][I][i2c.arduino:096]: Results from i2c bus scan:
[17:49:27][I][i2c.arduino:102]: Found i2c device at address 0x76
[17:49:27][C][bmp280_i2c.sensor:022]: Address: 0x76
[17:49:27][C][bmp280.sensor:132]: BMP280:
[17:49:27][C][bmp280.sensor:144]: IIR Filter: OFF
[17:49:27][C][bmp280.sensor:145]: Update Interval: 60.0s
[17:49:27][C][bmp280.sensor:147]: Temperature ‘AV cupboard temperature’
[17:49:27][C][bmp280.sensor:147]: Device Class: ‘temperature’
[17:49:27][C][bmp280.sensor:147]: State Class: ‘measurement’
[17:49:27][C][bmp280.sensor:147]: Unit of Measurement: ‘°C’
[17:49:27][C][bmp280.sensor:147]: Accuracy Decimals: 1
[17:49:27][C][bmp280.sensor:148]: Oversampling: 16x
[17:49:27][C][bmp280.sensor:149]: Pressure ‘AV cupboard pressure’
[17:49:27][C][bmp280.sensor:149]: Device Class: ‘pressure’
[17:49:27][C][bmp280.sensor:149]: State Class: ‘measurement’
[17:49:27][C][bmp280.sensor:149]: Unit of Measurement: ‘hPa’
[17:49:27][C][bmp280.sensor:149]: Accuracy Decimals: 1
[17:49:27][C][bmp280.sensor:150]: Oversampling: 16x
[17:49:27][C][captive_portal:089]: Captive Portal:
[17:49:27][C][web_server:145]: Web Server:
[17:49:27][C][web_server:146]: Address: av-cupboard-temperature-sensor.local:80
[17:49:27][C][mdns:116]: mDNS:
[17:49:27][C][mdns:117]: Hostname: av-cupboard-temperature-sensor
[17:49:27][C][esphome.ota:073]: Over-The-Air updates:
[17:49:27][C][esphome.ota:074]: Address: av-cupboard-temperature-sensor.local:8266
[17:49:27][C][esphome.ota:075]: Version: 2
[17:49:27][C][esphome.ota:078]: Password configured
[17:49:27][C][safe_mode:018]: Safe Mode:
[17:49:27][C][safe_mode:019]: Boot considered successful after 60 seconds
[17:49:27][C][safe_mode:021]: Invoke after 10 boot attempts
[17:49:27][C][safe_mode:022]: Remain in safe mode for 300 seconds
[17:49:27][C][api:139]: API Server:
[17:49:27][C][api:140]: Address: av-cupboard-temperature-sensor.local:6053
[17:49:27][C][api:142]: Using noise encryption: YES
nickrout
(Nick Rout)
September 28, 2024, 11:41pm
2
Please post your yaml correctly.
substitutions:
esphome:
project:
version: dev
esp8266:
board: nodemcuv2
framework:
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
encryption:
# Allow Over-The-Air updates
ota:
platform: esphome
# Allow provisioning Wi-Fi via serial
# improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
#dashboard_import:
# package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
# import_full_config: true
# To have a "next url" for improv serial
web_server:
port: 80
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: bmp280_i2c
i2c_id: bus_a
address: 0x76
temperature:
name: "AV cupboard temperature"
#id: av_cupboard_temperature
#oversampling: 16x
pressure:
name: "AV cupboard pressure"
#id: av_cupboard_pressure
Verbose logs are as follows
[18:26:57][C][logger:185]: Logger:
[18:26:57][C][logger:186]: Level: VERY_VERBOSE
[18:26:57][C][logger:188]: Log Baud Rate: 115200
[18:26:57][C][logger:189]: Hardware UART: UART0
[18:26:57][C][i2c.arduino:071]: I2C Bus:
[18:26:57][C][i2c.arduino:072]: SDA Pin: GPIO4
[18:26:57][C][i2c.arduino:073]: SCL Pin: GPIO5
[18:26:57][C][i2c.arduino:074]: Frequency: 50000 Hz
[18:26:57][C][i2c.arduino:086]: Recovery: bus successfully recovered
[18:26:57][I][i2c.arduino:096]: Results from i2c bus scan:
[18:26:57][I][i2c.arduino:102]: Found i2c device at address 0x76
[18:26:57][C][bmp280_i2c.sensor:022]: Address: 0x76
[18:26:57][C][bmp280.sensor:132]: BMP280:
[18:26:57][C][bmp280.sensor:144]: IIR Filter: OFF
[18:26:57][C][bmp280.sensor:145]: Update Interval: 60.0s
[18:26:57][C][bmp280.sensor:147]: Temperature 'AV cupboard temperature'
[18:26:57][C][bmp280.sensor:147]: Device Class: 'temperature'
[18:26:57][C][bmp280.sensor:147]: State Class: 'measurement'
[18:26:57][C][bmp280.sensor:147]: Unit of Measurement: '°C'
[18:26:57][C][bmp280.sensor:147]: Accuracy Decimals: 1
[18:26:57][C][bmp280.sensor:148]: Oversampling: 16x
[18:26:57][C][bmp280.sensor:149]: Pressure 'AV cupboard pressure'
[18:26:57][C][bmp280.sensor:149]: Device Class: 'pressure'
[18:26:57][C][bmp280.sensor:149]: State Class: 'measurement'
[18:26:57][C][bmp280.sensor:149]: Unit of Measurement: 'hPa'
[18:26:57][C][bmp280.sensor:149]: Accuracy Decimals: 1
[18:26:57][C][bmp280.sensor:150]: Oversampling: 16x
[18:26:57][C][captive_portal:089]: Captive Portal:
[18:26:57][C][web_server:145]: Web Server:
[18:26:57][C][web_server:146]: Address: av-cupboard-temperature-sensor.local:21080
[18:26:57][C][mdns:116]: mDNS:
[18:26:57][C][mdns:117]: Hostname: av-cupboard-temperature-sensor
[18:26:57][V][mdns:118]: Services:
[18:26:57][V][mdns:120]: - _esphomelib, _tcp, 6053
[18:26:57][V][mdns:122]: TXT: friendly_name = av-cupboard-sensor
[18:26:57][V][mdns:122]: TXT: version = 2024.9.1
[18:26:57][V][mdns:122]: TXT: mac = c8c9a3261215
[18:26:57][V][mdns:122]: TXT: platform = ESP8266
[18:26:57][V][mdns:122]: TXT: board = nodemcuv2
[18:26:57][V][mdns:122]: TXT: network = wifi
[18:26:57][V][mdns:122]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[18:26:57][V][mdns:122]: TXT: project_name = esphome.web
[18:26:57][V][mdns:122]: TXT: project_version = dev
[18:26:57][V][mdns:120]: - _http, _tcp, 21080
[18:26:57][C][esphome.ota:073]: Over-The-Air updates:
[18:26:57][C][esphome.ota:074]: Address: av-cupboard-temperature-sensor.local:8266
[18:26:57][C][esphome.ota:075]: Version: 2
[18:26:57][C][esphome.ota:078]: Password configured
[18:26:58][C][safe_mode:018]: Safe Mode:
[18:26:58][C][safe_mode:019]: Boot considered successful after 60 seconds
[18:26:58][C][safe_mode:021]: Invoke after 10 boot attempts
[18:26:58][C][safe_mode:022]: Remain in safe mode for 300 seconds
[18:26:58][C][api:139]: API Server:
[18:26:58][C][api:140]: Address: av-cupboard-temperature-sensor.local:6053
[18:26:58][C][api:142]: Using noise encryption: YES
[18:27:05][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=21394 (now=31394)
[18:27:15][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=31394 (now=41395)
[18:27:17][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=4294950473 (now=43177)
[18:27:17][VV][scheduler:225]: Running interval 'update' with interval=60000 last_execution=4294950729 (now=43433)
[18:27:17][V][bmp280.sensor:158]: Sending conversion request...
[18:27:17][VV][i2c.arduino:176]: 0x76 TX F4B5
[18:27:17][VV][i2c.arduino:202]: TX failed: not acknowledged: 2
[18:27:25][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=41394 (now=51399)
[18:27:33][VV][api.service:697]: on_ping_request: PingRequest {}
[18:27:33][VV][api.service:043]: send_ping_response: PingResponse {}
[18:27:35][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=51394 (now=61397)
[18:27:38][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[18:27:45][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=61394 (now=71394)
[18:27:55][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=71394 (now=81395)
[18:27:57][VV][api.connection:132]: Sending keepalive PING...
[18:27:57][VV][api.service:037]: send_ping_request: PingRequest {}
[18:27:57][VV][api.service:706]: on_ping_response: PingResponse {}
[18:28:05][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=81394 (now=91394)
[18:28:13][VV][api.service:697]: on_ping_request: PingRequest {}
[18:28:13][VV][api.service:043]: send_ping_response: PingResponse {}
[18:28:15][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=91394 (now=101394)
[18:28:17][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=43177 (now=103177)
[18:28:17][VV][scheduler:225]: Running interval 'update' with interval=60000 last_execution=43433 (now=103438)
[18:28:17][V][bmp280.sensor:158]: Sending conversion request...
[18:28:17][VV][i2c.arduino:176]: 0x76 TX F4B5
[18:28:17][VV][i2c.arduino:202]: TX failed: not acknowledged: 2
[18:28:25][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=101394 (now=111394)
[18:28:35][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=111394 (now=121394)
[18:28:45][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=121394 (now=131394)
[18:28:53][VV][api.service:697]: on_ping_request: PingRequest {}
[18:28:53][VV][api.service:043]: send_ping_response: PingResponse {}
[18:28:55][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=131394 (now=141397)
[18:28:57][VV][api.connection:132]: Sending keepalive PING...
[18:28:57][VV][api.service:037]: send_ping_request: PingRequest {}
[18:28:57][VV][api.service:706]: on_ping_response: PingResponse {}
[18:29:05][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=141394 (now=151394)
[18:29:15][VV][scheduler:225]: Running interval '' with interval=10000 last_execution=151394 (now=161394)
[18:29:17][VV][scheduler:225]: Running interval '' with interval=60000 last_execution=103177 (now=163177)
[18:29:17][VV][scheduler:225]: Running interval 'update' with interval=60000 last_execution=103433 (now=163435)
nickrout
(Nick Rout)
September 29, 2024, 7:54pm
4
Thanks for that, I can’t find the term “numeric” in either of your logs. Perhaps it needs to run longer for the error to show.
I do see i2c errors though. Please make sure you check your wiring, pullups etc.
You mention upgrading to 2024.9.1. What was the last working version? Does it work if you downgrade esphome?
The error shows in the UI
