BMW ConnectedDrive component
The component released in version 98 is looking good. I can see the sunroof state even when it’s tilted open. Great!
I see there are some new icons on the overview, those are nice, too.
Re: maxfuel sensor. It still doesn’t have a unit attached. On my i3, this shows 8. Just 8. Not eight gills or 8 cups or 8 cubic centimeters. Just 8. My guess is this is 8 liters, because my fuel remaining sensor shows 2 (Imperial, not US*) gallons – and I think the tank is full – and with one significant figure, there’s 4 liters/gallon. This sensor should have a unit attached, and converted to the user’s units when required.
*This is another separate, unrelated, but significant bug in Home Assistant itself: US units of measure are not supported, only Imperial and SI. And particularly in volume units, these measures are meaningfully different.
Im also running the 98.1 but I still get lots of errors in the log when I try to add my F11:
remote services are booked and the app on my iPhone works as intended.
2019-08-30 22:15:40 ERROR (MainThread) [homeassistant.setup] Error during setup of component bmw_connected_drive
  File "/usr/src/homeassistant/homeassistant/setup.py", line 172, in _async_setup_component
    component.setup, hass, processed_config  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/__init__.py", line 49, in setup
    accounts.append(setup_account(account_config, hass, name))
  File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/__init__.py", line 77, in setup_account
    cd_account = BMWConnectedDriveAccount(username, password, region, name, read_only)
  File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/__init__.py", line 127, in __init__
    self.account = ConnectedDriveAccount(username, password, region)
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/account.py", line 55, in __init__
    self._get_vehicles()
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/account.py", line 192, in _get_vehicles
    logfilename='vehicles')
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/account.py", line 136, in send_request
    raise IOError(msg)
OSError: The BMW Connected Drive portal returned an error: SERVER_ERROR (received status code 500 and expected 200).
bmw_connected_drive:
  name:
    username: !secret bmw_cd_user
    password: !secret bmw_cd_pw
    region: rest_of_world
    read_only: true
anyone an idea what im doing wrong?
This is caused by the Connected Drive portal not being able to process the request correctly. Just restart HA a few times until it works. Check this post as well → BMW ConnectedDrive component - #464 by WhimsySpoon
Great to hear the sunroof is working correctly now :grinning:
Can you make an issue on bimmer_connected Github for the maxfuel sensor including a screenshot of the entity with it’s attributes? Looks like that sensor is not setup with a unit yet.
Did it.
Also, what do you think of unit “%” for HV battery (charging_level_hv)? It seems to be possible in general. E.g., the component for Epson Ecotank printers shows the remaining ink levels as %.
Thanks. Yes the percentage for charging_level_hv can be added.
Have some more questions on other sensors added to the GH issue.
Can I request that we NOT add % sign? I use the battery level in some notification automations inside NodeRED and I need it to be a number only for it to work. Perhaps a separate sensor that includes % sign could be created so we can choose which one we need for our HA?
This will be no issue as the state of the entity will stay the same. I will just add an unit of measurement attribute to the entity. HA uses that to show it in the frontend, but the state will not have the % so you can still use Nodered :smile:
Is it possible to get the turn on remote climate functionality or is that available in the apis?
3D remote view would also be nice :wink:
The remote climate service is already supported, the howto is described in the docs -> https://www.home-assistant.io/components/bmw_connected_drive/
My bad, I actually forgot I already set that up :sweat_smile:
Is it possible to actually get confirmation back that did execute successfully? Would be nice to set up a notification with simplePush to say hey this is done (because it fails sometimes even in the BMW app)
@gerard33 Would it be possible to include some retry login in the start up of the component?
I know this isn’t an issue with the component, rather BMW’s unreliable web service, but its painful if I need to restart HA because I’ve made a change to my config (totally unrelated to this component), only to find that I need to restart it another couple of times just to get a good connection to their web service.
I was thinking of that myself as well and checked it on Discord and that’s indeed possible.
Will do some testing and make a PR for this.
That’s great news, thanks! Happy to assist with any testing.
Hmm saw this in the sensor list for my 330e: 330e chargingInductivePositioning
I wonder if it has support for wireless charging… :thinking:
Getting the error. Any help?
Worked before on my 0.93 version. Made a fresh install on OS and HA 100.03. Now i got this error.
HTTPSConnectionPool(host='b2vapi.bmwgroup.com', port=443): Max retries exceeded with url: /gcdm/oauth/token (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')])")))
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 485, in wrap_socket
    cnx.do_handshake()
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1915, in do_handshake
    self._raise_ssl_error(self._ssl, result)
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1647, in _raise_ssl_error
    _raise_current_error()
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py", line 54, in exception_from_error_queue
    raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')]
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
    chunked=chunked,
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connectionpool.py", line 376, in _make_request
    self._validate_conn(conn)
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connectionpool.py", line 994, in _validate_conn
    conn.connect()
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connection.py", line 394, in connect
    ssl_context=context,
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 370, in ssl_wrap_socket
    return context.wrap_socket(sock, server_hostname=server_hostname)
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 491, in wrap_socket
    raise ssl.SSLError("bad handshake: %r" % e)
ssl.SSLError: ("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')])",)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
    method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
  File "/srv/homeassistant/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='b2vapi.bmwgroup.com', port=443): Max retries exceeded with url: /gcdm/oauth/token (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')])")))
  File "/srv/homeassistant/lib/python3.7/site-packages/bimmer_connected/account.py", line 89, in _get_oauth_token
    expected_response=200, post=True)
  File "/srv/homeassistant/lib/python3.7/site-packages/bimmer_connected/account.py", line 126, in send_request
    response = requests.post(url, headers=headers, data=data, allow_redirects=allow_redirects, params=params)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.7/site-packages/requests/adapters.py", line 514, in send
    raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='b2vapi.bmwgroup.com', port=443): Max retries exceeded with url: /gcdm/oauth/token (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'ssl_choose_client_version', 'unsupported protocol')])")))
You probably also installed Debian Buster at the same time?
In that case you can check here for the solution.
Indeed. Thanks for the fast help. I’ll check the workound tomorrow. Seems to be the config of openssl
Setting up new
Error from home-assistant: The BMW Connected Drive portal returned an error: SERVER_ERROR (received status code 500 and expected 200).
I would greatly appreciate any help!
EDIT: I see people say to restart. i’ve done that several times. I am also not paying anything for the connected+ . seems i may need to have that. but not sure why i would get these errors.
Here is my config:
  name:
    username: !secret email
    password: !secret passwordbmw
I am in switzerland. my account is on https://www.bmw-connecteddrive.ch/
I am running home-assistant 0.101.2
here is relevant log:
2019-11-06 19:16:12 ERROR (SyncWorker_14) [homeassistant.components.bmw_connected_drive] Could not connect to the BMW Connected Drive portal. The vehicle state could not be updated.
2019-11-06 19:16:12 ERROR (SyncWorker_14) [homeassistant.components.bmw_connected_drive] The BMW Connected Drive portal returned an error: SERVER_ERROR (received status code 500 and expected 200).
  File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/__init__.py", line 142, in update
    self.account.update_vehicle_states()
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/account.py", line 215, in update_vehicle_states
    car.update_state()
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/vehicle.py", line 72, in update_state
    self.state.update_data()
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/state.py", line 130, in update_data
    params=params)
    raise IOError(msg)
running HA 0.101.3
newbee here on HA.
I have the same errors when running the BMW ConnectedDrive integration:
bmw_connected_drive.activate_air_conditioning / { “vin”:“WBANXXXXXX1234567” }
The app on my iPhone works like a charm, also when connecting to www.bmw-connecteddrive.nl I have no issues.
2019-11-08 15:26:34 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1884274320] The BMW Connected Drive portal returned an error: SERVER_ERROR (received status code 500 and expected 200).
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
    connection.context(msg),
  File "/usr/src/homeassistant/homeassistant/core.py", line 1236, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/src/homeassistant/homeassistant/core.py", line 1263, in _execute_service
    await self._hass.async_add_executor_job(handler.func, service_call)
  File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/__init__.py", line 94, in execute_service
    function_call()
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/remote_services.py", line 120, in trigger_remote_air_conditioning
    self._trigger_remote_service(_Services.REMOTE_AIR_CONDITIONING, post=True)
  File "/usr/local/lib/python3.7/site-packages/bimmer_connected/remote_services.py", line 133, in _trigger_remote_service
    return self._account.send_request(url, post=post, data=data)
    raise IOError(msg)
