Yes, the BMW integration is not yet part of the integrations (PR is made for that).
Added the read_only
tag to see if there was any change earlier, no difference - same error with or without the entry. Removed for now.
Using the sample VIN gives the same error:
Failed to call service bmw_connected_drive/activate_air_conditioning. 'str' object has no attribute 'read_only'
Think Iāve found the issue. Originally, I had a HACS install when doing some troubleshooting a couple of months ago, i removed that folder and rebooted HA and everything seems to be functional at the moment.
I just followed the following steps:
- car is locked via the remote key
binary_sensor.x1_lock_state = off
lock.x1_lock = locked
- I called the
lock.unlock
service
binary_sensor.x1_lock_state = on
lock.x1_lock = unlocked
- I called the
lock.lock
service
So this works as expected. Strange that itās not working for you. Have you taken into consideration that the status of the binary sensor will be updated after the next interval? So that can take up to 5 minutes. You can call the service bmw_connected_drive.update_state
to get this status back immediately.
Thatās correct. The car alarm will only be activated when closing it with the remote key.
Hi, thatās the trick. I did not wait long enough.
Tested it and everything works as you described.
Apologies if this is some kind of error on my part as Iāve just dived into Home Assistant.
I got BMW_Connected_Drive working with HA and HomeKit so that I can successfully lock/unlock my X3 from Appleās Home app and even start/stop the climatization feature.
My issue is that the Parking Lights show up as a āOccupancy Sensorā in HomeKit instead of a Light switch. When I look in Home Assistant, the entity is written out as ābinary_sensor.x3_xdrive30e_lights_parkingā. If I try to change the entity name to ālight.x3_xdrive30e_lights_parkingā I get an error ādomain needs to remain the sameā. Is there a config I should be updating to change it from a sensor to a light?
I donāt believe the integration allows the parking lights to be turned on or off, thatās why it shows up as a sensor. But I have an i3 not an x3 so maybe thereās a chance things could function differently for your car. You could maybe call a service to flash the lights as mentioned here
āThe service bmw_connected_drive.light_flash flashes the lights of the vehicle. The vehicle is identified via the parameter vin.ā
@elaren The above is correct. Itās only possible to get the state of the parking lights (this is the same for all cars) and not turn them on or off via the integration. Thatās why itās a binary sensor and not a light sensor which you can turn on and off.
Hi, is there any solution for executionStatus
errors? I noticed there is a closed issue in github with recent update without reply (basically the same config as the last post, even the error details, except my car is G05).
I get this error as well everytime i try to execute something. But despite the error, the calls soon or later works.
Iāve got 530e and it would be great if there was a service for starting immediate charging. Problem is that I would like to heat up the cabin before driving but it takes so much power that it reduces the electric range for about 10km (range is not that good during winter anyway). If it was possible to call a service that starts the charging immediately, the power used during the heat up would come from the connected charger and not from the battery. Unfortunately, due to a bad design I would say, it seems that BMW does not start the charging without a trigger even if the battery level goes down due to heating.
With this service I could trigger the charging automatically always when heating is started. Any change to get this service included in this component? Would try to implement it myself but I have no experience on Python and I understood nothing by looking at the codeā¦ This service should be possible to implement though as it is available in the BMW app (which is horrible btw).
Can you make a FR here -> https://github.com/bimmerconnected/bimmer_connected/issues/new?assignees=&labels=&template=feature_request.md
And please share some screenshots of the app with the immediate charging service.
I did that, thanks!
Is there anything i can do to solve the executionStatus
issue?
I need to correct my previous message. I did more research and it actually seems that charging is started when heating starts eating the battery. But I suspect the charging mode needs to be āimmediateā in this case.
Still it would be nice to see this feature in HA! I saw some work done on getting data of all trips out of the car (consumptions, speed, etc). This is something that even the BMW app cannot do, so that wouldnt it be awesome to have something like that?!
I upgraded my car and Iām trying to get the connecteddrive component to deal with the change. I had an i3 and now I have a newer i3.
It didnāt seem to pick up my connecteddrive changes. So I removed the config from configuration.yaml, restarted, removed all the entities that now were unavailable. Then I put the config back and restarted again.
This picked up the car, but all the entities were named like ābinary_sensor.i3s_120_charging_statusā. I just want plain āi3ā, not āi3s_120ā.
Can I control this? I put into known_devices :
i3s_120:
icon: mdi:car
mac:
picture:
track: true
However Iām not sure where this ānameā pulls through to. Certainly didnāt change the entity names.
What Iām particularly about is to have Alexa see it as āi3ā. Right now Alexa has āi3s 120ā which doesnāt exactly roll off the tongueā¦
I can manually rename in the Alexa app but its quite a lot of devices.
Thanks for hints and advice!
Steve
The integration uses the car model from the BMW ConnectedDrive API. Your new i3 is called i3s_120 there, so that name is used in the entity ids.
You can change the entity ids (e.g. binary_sensor.i3s_120_charging_status
) by clicking on the entity and then in the popup window on the cog in the upper right corner. Then you can rename the entity id there to binary_sensor.i3_charging_status
For use with Alexa though it is not necessary to rename the entity id, just renaming the entity name should work. You can do this in the same popup window.
Only the device tracker is controlled in known_devices.yaml
Anyone else getting Authentication Errors from the integration today?
My password hasnāt changed and the BMW App on my phone still worksā¦
No error for me
Yep, same for me.
I am getting the same error.
