Confirmed. Rebooted earlier and I’m getting authentication errors. Able to log into connected drive on the website OK.
Logger: bimmer_connected.account
Source: /usr/local/lib/python3.8/site-packages/bimmer_connected/account.py:115
First occurred: 12:41:37 (1 occurrences)
Last logged: 12:41:37
Authentication failed. Maybe your password is invalid?
Same here. I actually did something to my secrets.yaml right before the reboot, but reverting to the “old” secrets.yaml did not help either. Error stays the same after each reboot
Dani_Leal
(Dani Leal)
October 20, 2020, 9:30pm
631
Same here! Does anyone know what can happen?
Reik
October 21, 2020, 6:56am
633
Yes! Same error for me. App works but HA does not.
same here
there is already a issue open for that
opened 09:38AM - 20 Oct 20 UTC
I'm not be able to use the api..
even if I change the password..
(I'm able to login on bmw connect drive portal...
martynhr
(Martyn)
October 21, 2020, 7:40am
635
Same here. And the same issue with Audi
Same for me:
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
Abertil
(Andreas Jonasson)
October 21, 2020, 12:05pm
637
I tried the workaround from the above mentioned issue: https://github.com/bimmerconnected/bimmer_connected/compare/master...rikroe:fix/connection_refused
And at least the component is working again.
deluxestyle
(Deluxestyle)
October 21, 2020, 12:36pm
638
I tried the workaround as well and it seems to work for me
Dani_Leal
(Dani Leal)
October 21, 2020, 12:57pm
639
any solution for those of us who have HA and not core Docker?
gerard33
(Gerard 🇳🇱)
October 22, 2020, 5:50pm
640
PR with the fix is made by @rikroe -> https://github.com/home-assistant/core/pull/42215
Hopefully it will be merged as hotfix in 0.117. It’s merged as hotfix in the beta and will be part of 0.117.
If you want to fix it in the meanwhile you can check here for instructions -> https://github.com/home-assistant/core/issues/42139 .
sender
October 28, 2020, 9:25pm
641
It’s not in the release notes… is it merged?
sergio_pt
(Sergio_PT)
October 28, 2020, 11:13pm
642
Yep. Working after upgrade
Sparks
(John van Veggel)
October 29, 2020, 8:19am
643
Confirmed to be fully functional again after update to 0.117.0 !
Grtz
John
sender
October 29, 2020, 9:08am
644
yes, 117 solves it! thanks all!
deluxestyle
(Deluxestyle)
November 16, 2020, 1:04pm
645
after a restart of HA today it seems again a problem with the login
anyone else facing the same issue?
sender
November 16, 2020, 1:36pm
647
BMW has a “new” app, called “my BMW” might have to do with?
As usual the app sucks… less functionality than before (cannot horn and flash light).
