BodyZone Connect electric blanket
I bought a Breville “BodyZone Connect” Wi-Fi-enabled electric blanket thinking it would almost certainly use a technology with an existing Home Assistant integration—but I might be wrong. I thought it might be Home Connect, but after going through all of the configuration steps for that, I don’t seem to be any closer.
Does anyone recognise this app? Any ideas for how I might determine the underlying technology?
LZB558-dna1
The hardware controller itself:
  • only connects to 2.4GHz Wi-Fi.
  • goes into “connection mode” by holding its ENTER button down for eight (8) seconds.
  • makes one (1) single DNS query to a29ik4352bkxp2.iot.ap-southeast-2.amazonaws.com, which has four (4) open TCP ports: 443, 8192, 8443, and 8883.
  • doesn’t seem to have any open ports of its own.
  • seems to try to send some sort of encrypted traffic to the 8883 port—but I don’t know how to investigate beyond that.
The app:
  • hits a29ik4352bkxp2-ats.iot.ap-southeast-2.amazonaws.com, which has the same TCP ports open.
I’ve since worked out that:
  • The “Plus” version of the product is what connects using Home Connect (and this seems to be literally the only difference between the two products, other than cost and availability)
  • My “non-Plus” version appears to be using AWS IoT, which probably won’t ever be integrable.
My options, in order of decreasing effort, seem to be:
  • Crack the controller open and see whether it might be flashable (I have zero knowledge of these things)
  • Try reverse-engineering the traffic, and with the help of a local DNS server, reroute the traffic to some local, custom-written web server
  • See if the manufacturer is willing to swap the controllers over for the “Plus” controllers (which from all available images seem to have the exact same connector to the blanket)
  • Give this one away and purchase the “Plus” version
  • Deal with the awful included phone app exclusively
  • Have no automation.
If anyone comes across this thread in future and thinks that together we might be able to get this non-Plus blanket (with its BodyZone Connect app) working with Home Assistant, please, absolutely reach out.
I bought (and thought) the same electric blanket.
It is a white labelled Tuya device which HA will identify.
The Tuya integration however does not support the electric blanket - and so whilst I have the integration installed, I have 2 devices with no entities.
Not happy…
I have this issue also. I bought mine around May 2023, connected it with no guidance supplied. It worked okay until earlier this year when I had to upgrade my ISPs router due to dropouts, and have not been able to connect the Bodyzone since. It has driven me crazy. I went through their support who had no idea, and gave up so easily that they gave me a code to be able to return it to Harvey Norman, which I did not do, because i need this feature, and there doesnt seem to be any other brand with working app. After seeing your post, Im tempted to get back in touch with Breville support and get a new code to return it, so i can try to get the Plus.
For anyone interested:
  • I ended up donating the non-Plus blanket away and purchasing the Plus version.
  • The Plus version paired up nicely in the Tuya Smart app on my phone.
  • I was then able to add the device in Home Assistant via the Local Tuya integration (I had previously gone through all the necessary hoops to pair my Tuya cloud account with a developer account so that I could obtain keys, etc.—the inbuilt Tuya integration would probably also work).
Through some trial and error I worked out all the different data points:
  • DP 1: power. Set up as a switch.
  • DP 4: “edit mode”, for lack of a better term. I’ve set this up as a select with entries Level1;Level2;None and “user-friendly” options Top;Bottom;None purely for completeness, but it doesn’t seem to be necessary. It changes to:
    • Level1 when pressing the HEAT button on the controller and the chest flashes
    • Level2 when pressing the HEAT button on the controller and the legs flash
    • None when the TIMER button is pressed and the hour digit flashes.
  • DP 7: whether or not the controller has detected an error condition. Set up as a binary_sensor with 0 meaning OFF and 1 meaning ON. I chose problem as the sensor class. Turns ON if the controller is disconnected from the blanket, for example.
  • DP 14: top zone heat. Set up as a select with entries level_1;level_2;level_3;level_4;level_5;level_6;level_7 and user-friendly options 0;1;2;3;4;5;6 to match what is shown on the controller.
  • DP 15: bottom zone heat. As above.
  • DP 16: timer. Set up as a select with entries cancel;1h;2h;3h;4h;5h;6h;7h;8h;9h and user-friendly options 0;1;2;3;4;5;6;7;8;9. When set in HA to 1–9, is equivalent to setting 1–9 on the controller. When the hour lapses, the controller display decrements but the value in HA does not. If set to 0/cancel via HA, 0 shows on the controller and the heat settings seem to apply indefinitely.
I’m looking forward to combining all of these entities into a sensible button-card layout in due course. I’d be happy to share my end result here if there’s any interest.
Snap… I’ve just finished implementing a similar solution after some researching and mucking around.
I used the below page to guide me through the local tuya integration and linking to the tuya dev portal…
Agree - dashboarding this nicely is the next step. Looking at using custom layout cards
I harassed Breville for support, who has no idea what to try so they gave me a return code, and I returned it to Harvey Norman for full refund after a year.
I used the money to get the Goldair Bamboo WiFi blanket. It had the same issue. I googled more and found this on YouTube;
I turned off the 5g band and brought the elec blanket to my desk and plugged it in, connected it to 2.4g, took it back to bedroom and plugged it in. It worked. Only I think it was right on the edge of the Max distance, because I dragged the router a little closer and it seems connected and working.
At least we all got there in the end. And I made $90 back
Hey Justin,
Were you able to get the Goldair Heated Blanket onto Home Assistant? Is it a Tuya based device? Looking into heated blankets at the moment as well.
Thanks!
Hi Justin. Time for me to get a new blanket and found the Goldair Bamboo King Luxury Quilted Electric Blanket with Wi-Fi … so also wondering if you got it into HA ? I assume it is using Tuya ?
I bought the Goldair Wi-Fi Electric Blanket. In Aus this model was discontinued product in Sept 2024, so not much stock around.
I eventually paired both controllers with Tuya app on my phone (though the instruction to enter pairing mode is wrong); and I was able to determine DP_IDs.
Curiously during this I managed to get 2 different MAC addresses from one of the controllers.
With a bit of testing I found a fault which will result in me taking it back for refund. FYI this is the message I sent to Goldair :
I bought a Goldair Wi-Fi Electric Blanket and after a fair bit of fiddling managed to get both controllers paired. The instructions in user manual are NOT CORRECT, and not helped by the two controllers behaving differently when [Timer] is pressed.
I found that after power is removed (eg power cut or turned off at the wall socket) the device does not automatically reconnect to Wi-Fi when power is available. Your blanket does not start up with heating on, so this cannot be a safety issue.
Then surely when the user presses the [On-Off] button on the controller it would reconnect to Wi-Fi ? … but no, the user is required to re-pair each controller. This will be beyond my elderly partner’s technical ability, and is sure to create significant dis-satisfaction.
My reason for purchasing Wi-Fi is to use automation to simplify life. However if a power cut happens during the day it won’t be until bedtime that she discovers that the blanket is OFF. Manually turning it ON allows her to heat the bed - for that night - but will not restore the wi-fi and automation. In short, this is a fault which invalidates the benefit of having Wi-Fi.
I will be better off with a basic blanket which can be preset to heat 3 and a couple of cheap smart power points to turn the blanket on and off.
I cannot think of any wi-fi enabled device that does not automatically reconnect the wi-fi when power is applied. It certainly is not standard operation for other devices which use Tuya firmware (as yours does).
