I have been googling and it seems that the most common installation is Raspbian and then BOINC in SSH using the GUI to control which project to support:
I was hoping that I could use my Raspbery pi 4 (4GB), since it is running Hass.io and are on all the time. So it would save me some money just to have one SBC running everything.
But how do I access the Boinc manager without a gui? my first though was to install boinc manager on a windows computer or something external but I cant seem to find such a program so I think I am missing something in the installation. And he is using an Intel build in his guide so sadly I cant use it more after in container instalation.
Edit:
I found this solution for running boinic on openmediavault. I guess the solution can be the same in Hass.io if you use docker and ssh. So if other people is also interested then it might help. Sadly I have i tested it myself because of health issues.
Hi
is it really easier install portainer and run a docker with boinc? and which is safier? what are the minimum security properties i should set in portainer for this (or any docker in hassio).
i have not many experience but i see portainer needs to disable “Protection mode” doesnt not require more more privileges than a addon ?
