I use Bond’s “trust tracked state” feature with a toggling-only light. It works great, most of the time. Every few days I have to go into the Bond app and hit the “fix tracked state” switch when things get out of sync.
I’d really like to be able to do this via Home Assistant. Primarily because I’m going to add a Lutron Pico remote (can’t use the RF remote if we’re tracking state) and want to program the “fix tracked state” command to one of the Pico buttons, so my wife stops asking me to fix it for her! For this I need Home Assistant to be able to send that command.
I believe this should be a first-class feature in the integration, but this is working for me in the meantime. Only real downside is once you flip the state belief switch, it takes a few seconds for the light state to update in HA. Not sure if there’s any way to force a refresh. But it works.
This would be a great addition to the Bond Integration. I am in a similar situation where the state gets out of sync on the bond periodically primarily due to someone using an RF Remote. It is not a big issue other than needing to go through the Bond App to fix it takes a more menus than desired. A simple toggle or button in HA to do it would be great. Jeremy’s script is great, (I have 9 devices controlled by the bond but the only change will be the device ID, so I can handle that via a parameter in an script call) but this would be so much simpler if a Service Data element was added for “fix_tracked_state” and defaulted to “false” that could be used for either toggle, turn_on, or turn_off to have the service call just update the state and not cause the command to be performed.
