Bond just release a beta of their local API
http://docs-local.appbond.com/
It would be awesome if somebody could integrate this into HA.
Has anyone been able to use this yet? I just tested on my own BOND device and so far it seems like I don’t have the firmware version with this feature. App shows me on v1.138.1
You have to first sign up for the beta program and then they’ll push the beta to your device once accepted.
I am still waiting for mine to get the beta fw.
Here’s a link to the signup details
Ah, I totally missed that. Seems I missed out on being able to sign up for the beta.
I ended up purchasing a brand new Bond device last week. If your serial number starts with ZZ, you can get the new firmware that includes the local API without signing up for anything. I’ve got the API working in Home Assistant now using shell commands, and can control my fans from automations. Really looking forward to a proper integration.
Can you share one of your shell command config entries?
Are you doing anything to capture on/off state?
I am not capturing the state of the light. Bond uses their own cloud MQTT server to track the light state, and it breaks if someone uses the remote manually, so I’m pretty sure it would be worthless locally too.
Here is how I control my master bedroom fan with shell commands:
# Master Bedroom Fan Controls
mst_fan_light_toggle: 'curl -H "BOND-Token: xxxxxxxxxxxxxxxx" -i http://x.x.x.x/v2/devices/fan_id/commands/command_id/tx -X PUT -d {}'
mst_fan_spd_1: 'curl -H "BOND-Token: xxxxxxxxxxxxxxxx" -i http://x.x.x.x/v2/devices/fan_id/commands/command_id/tx -X PUT -d {}'
mst_fan_spd_2: 'curl -H "BOND-Token: xxxxxxxxxxxxxxxx" -i http://x.x.x.x/v2/devices/fan_id/commands/command_id/tx -X PUT -d {}'
mst_fan_spd_3: 'curl -H "BOND-Token: xxxxxxxxxxxxxxxx" -i http://x.x.x.x/v2/devices/fan_id/commands/command_id/tx -X PUT -d {}'
mst_fan_pwr: 'curl -H "BOND-Token: xxxxxxxxxxxxxxxx" -i http://x.x.x.x/v2/devices/fan_id/commands/command_id/tx -X PUT -d {}'
You will need to replace the token, fan_id, and command_id with the items in your Bond API
It is open to the public now
Now I just need somebody to dumb it down for HA integration and I’ll be all set.
Awesome, thanks! I’ve got it working using some basic shell commands like mentioned above, along with a bunch if input_booleans and input_selects to create a template_switch, a switch_light, and a template_fan. It’s working, but is messy as hell.
Unfortunately the API doesn’t have the action or state functionality currently and the commands interface feels very clunky. I think any HA integration should wait until those exist.
Can you share the yaml you used to accomplish this?
Alright, I spent some time creating a much better, more robust, and entirely functional implementation that’ll work until the API leaves beta and a proper integration can be created.
I call it “Hacky Bond Integration”! It’s fairly long, so I put it up here:
https://pastebin.com/wHewNTtX
Some additional notes with further tinkering:
I already had a “switch” key in my config closer to the top like:
switch: !include_dir_merge_list switches
… and including another “switch” key was causing none of my other switches to be configured correctly. I just moved the switches for bond into a bond.yaml file in my switches directory. Seems this is true for most of the components, so you’ll likely need to break the yaml up depending on how your config file is set up.
I went ahead and created switches to toggle the fan on/off as well so that way I could control it via emulated_hue and homekit without needing to deal with homekit’s weird speed rules. I mostly just wanted the ability to toggle the fan on and off. Once the fan switch is in homekit you can set it as a fan and it has a fancy little animation.
So I have a BB serial Bond and I was very interested in doing this with mine. Unfortunately, all the Bonds that don’t have a ZZ serial number are still on version 1. I talked to Bonds customer service and they did tell me they’ll be upgrading all the remaining Bonds to V2 sometime this year which should give the rest of us access to the API. So fingers crossed. This would be the last integration I would need to have so I don’t have to go through IFTTT to access Bond through HA.
@MisterWil I could use a hand getting “Hacky Bond Integration” up and running. I was able to get all my API calls all tested and added to my shell_command.yaml file. When I try to execute them via the services panel I get nothing. I have the same strings added to the .bashrc file of my WSL debian instance as aliases and they fire every time. Is there a better way to test them?
Also I am having a problem wrapping my head around the scripts…
Do you get any errors when you execute the shell command from the services panel? You might have better luck converting them to rest commands like this (untested):
rest_command:
master_fan_light_toggle:
url: http://192.168.86.107/v2/devices/DEVICEID/commands/COMMANDID/tx
method: PUT
headers:
BOND_Token: xxxxxxxxxxxxxxxx
payload: '{}'
@MisterWil, I never even considered that! I tested the Restful approach using PostMan and that work alright. I am writing the config updates now, I will let you know how it goes…
Thanks!
UPDATE:
I got all the shell_commands converted to rest_commands and they work great!
example:
office_fan_light_toggle:
method: PUT
url: http://<BOND_ip_address>/v2/devices/<DEVICEID>/commands/<COMMANDID>/tx
headers:
content_type: 'application/json'
'BOND-Token': !secret BOND_Token
payload: '{}'
I was able to take the rest of your scripting and fully deploy my two fans! Thanks for the help!!
Awesome, I’m glad that’s working well! I haven’t had any issues with curl shell commands, and had I thought of it from the start I’d probably have used REST commands anyways.
@MisterWil I have all of the command strings added to my alias list in Linux and I have noticed that the Rest commands might actually be a little faster on the wire. Either way I am looking forward to being able to read state from the BOND. This is if the BOND can collect state from the fans…
Thanks for your help!!
Unfortunately, last I read, BOND will only keep track of state in the same way as my hacky integration does. That is, if anyone changes the fan with the fan’s real remote, or if the fan gets powered off at the switch and BOND is sending commands, then it’ll become out-of-sync with the actual state.
In any case, I’m looking forward to BOND finishing up their work so an actual HA integration can be developed.
Honestly, I am good with it. I changed the speed on a fan out of sync and I was back where I needed to be.
