Boost heating cancelling heating automation for 1 hour
Hi
I would like to create a button on dash board which when pressed turns on the heating for an hour and then turns off my heating automation which is already running. After the hour period. The boost button stops and the automation for the heating will carry on as normal. Simulating the boost option you get on a standard thermostat.
I have had no luck just going round in circles any ideas would be very much appreciated
Hiya
I used an automation that uses a timer to do this. I have a 1 hr boost button and a 2 hr boost button.
this is my automation
alias: Heating Boost (1hr)
description: "Turn Heating On, set temp of 22 for 1 hr then turn off. "
  - platform: state
    entity_id:
      - input_button.heating_1hr_boost
    id: Heating 1hr boost start
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id: timer.1_hr_heating_timer
    id: Heating 1hr boost stopped
condition:
  - condition: state
    entity_id: binary_sensor.anyone_home
    state: "on"
  - choose:
      - conditions:
          - condition: state
            entity_id: climate.heating
            state: "off"
          - condition: trigger
        sequence:
          - service: timer.start
            data: {}
          - service: climate.turn_on
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
          - service: climate.set_temperature
              temperature: 22
              hvac_mode: heat
          - service: tts.cloud_say
              entity_id: media_player.kitchen_display
              message: One hour heating boost is on
              cache: true
          - service: notify.ally_paul_devices
              message: 1 hr Heating Boost is on
              title: Heating
          - service: persistent_notification.create
              message: 1 Hr Heating Boost is On
              title: Heating
              notification_id: "001"
      - conditions:
        sequence:
          - service: climate.turn_off
            data: {}
              message: 1 Hr Heating Boost is Off
              title: Heating
              message: Heating Is off
              title: Heating
              message: Heating Boost is off
mode: single
This also checks to see if we are home and sends notification when it starts and when it stops. i also have another button that can cancel timers and boost.
It works quite well. it probally could be done better but it work๐Ÿ˜
Hope this helps
Let me no if ya need anymore info
cheers mate
that looks awesome. ill look at trying to use it. have you created a list of devices call ally_paul_devices? and what is rrs.cloud_say used for mate
Yeah
ally_paul hust lets me notify both of us. its a group i have had setup in configuration.yaml for forever๐Ÿ˜
  - platform: group
    services:
      - service: mobile_app_pixel_7_pro
      - service: mobile_app_allys_1_phone
the tts.cloud_say is to anounce it on my wee google display. i also do a persistant notification in home assistant. that also shows on phone. just lets ya see when it starts and finishes
You also need a wee timer helper setup for each boost. set them up in your devices&services/helpers
make sure you have restore ticked. means that if reboot happens during timer it will remember where it was
again.
Need any help ya know where i am
:ok_hand::grin:
i had to re do my dashboard and trying to re do this as it was good before. can you see below any reason why this wont call the 4 rooms to heat when i press run on the automation.
alias: heating boost automation 1 hour
description: 'Turn Heating On, set temp of 22 for 1 hr then turn off. โ€™
triggers:
  • entity_id:
    • input_button.heating_1hr_boost
      trigger: state
      to: โ€˜onโ€™
      actions:
  • choose:
    • conditions:
      • condition: trigger
        sequence:
      • data: {}
        action: timer.start
      • data: {}
        action: climate.turn_on
        entity_id:
        - climate.cot_room
        - climate.living_room
        - climate.our_room
        - climate.maeves_room
      • delay:
        hours: 0
        minutes: 0
        seconds: 5
        milliseconds: 0
      • data:
        temperature: 24
        hvac_mode: heat
        entity_id:
        - climate.cot_room
        - climate.our_room
        action: climate.set_temperature
      • data:
        title: Heating
        notification_id: โ€˜001โ€™
        action: persistent_notification.create
    • conditions:
        sequence:
      • data: {}
        entity_id:
        - climate.cot_room
        - climate.our_room
        action: climate.turn_off
      • data:
        title: Heating
        mode: single
cheers for your help
