Boot Homme Assistant Green
Hello
When we run our HA Green the first time , we got this alarme en the log file
2024-09-12 14:51:50.939 [Info] [main] [OnboardingAuth.swift:70] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1004 “Connexion au serveur impossible.” UserInfo={_kCFStreamErrorCodeKey=61, NSUnderlyingError=0x6000013ad980 {Error Domain=kCFErrorDomainCFNetwork Code=-1004 “(null)” UserInfo={_NSURLErrorNWPathKey=satisfied (Path is satisfied), viable, interface: en3, ipv4, ipv6, dns, _kCFStreamErrorCodeKey=61, _kCFStreamErrorDomainKey=1}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <179C5FAA-2073-443B-866A-FA412FF032F7>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
“LocalDataTask <179C5FAA-2073-443B-866A-FA412FF032F7>.<1>”
), NSLocalizedDescription=Connexion au serveur impossible., NSErrorFailingURLStringKey=http://192.168.1.39:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, NSErrorFailingURLKey=http://192.168.1.39:8123/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, _kCFStreamErrorDomainKey=1}), data: nil))
202
NSURLErrorDomain : We ignore of which domain it is question ?
We don’t use any firewall neither proxy
We connect our Mac and the HA Green directly ont the box internet
