Hello
I have encountered a rather weird Issue.
I wanted to include a way to control the volume of my media_player component, so I introduced a template number and have it set the volume of the player. I dont know if this is the recommended way of doing things, but it’s where I ran into the issue.
As soon as I had flashed the ESP, it became unresponsive. Some investigation made me realize that it was stuck in a bootloop. I have no way of confirming this, but it seems to me that the number component is getting initialized quite early in the setup() method. This in turn triggers the on_value automation, which wants to set the volume of the media player. however, I suspect that the media player is not yet set up at that point, which triggers a core panic.
Please tell me if I am doing things all wrong and/or if I should create a GitHub Issue for this.
Hard/software:
Wemos D1mini 32 (from this listing: https://www.aliexpress.com/item/4000880936043.html?spm=a2g0o.order_list.0.0.79db1802oL1pnn)
ESPHome c2022.11.1 trough a Home Assistant Add-On
Home Assistant 2022.11.4
Supervisor 2022.10.2
Operating System 9.3
Frontend 20221108.0 - latest
ESPHome config:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERY_VERBOSE
web_server:
# Enable Home Assistant API
api:
encryption:
key: "OwtJLMle/kNf5oi5Nd0Anger7rwB1JwAgRWxmikZ0OM="
ota:
password: "2f4457cb8f8986c4923f697d9395588e"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Nfc-Jukebox Fallback Hotspot"
password: "fBzHNljR0wqt"
captive_portal:
spi:
clk_pin: GPIO23
mosi_pin: GPIO18
miso_pin: GPIO33
pn532_spi:
cs_pin: GPIO26
update_interval: 1s
on_tag:
then:
- homeassistant.tag_scanned: !lambda |
if (!tag.has_ndef_message()) {
return x;
auto message = tag.get_ndef_message();
auto records = message->get_records();
for (auto &record : records) {
std::string payload = record->get_payload();
size_t pos = payload.find("https://www.home-assistant.io/tag/");
if (pos != std::string::npos) {
return payload.substr(pos + 34);
return x;
media_player:
- platform: i2s_audio
dac_type: external
i2s_lrclk_pin: GPIO32
i2s_dout_pin: GPIO22
i2s_bclk_pin: GPIO19
mode: stereo
button:
on_press:
then:
- media_player.play_media: 'https://www.liveatc.net/play/lszh1_twr.pls'
name: Play Energy Bern
on_press:
then:
- media_player.play_media: 'http://broadcast.infomaniak.ch/energybern-high.mp3'
on_press:
then:
- media_player.play_media: 'https://stream.srg-ssr.ch/m/drs3/aacp_96'
on_press:
then:
- media_player.play_media: 'https://grrif.ice.infomaniak.ch/grrif-128.aac'
name: Play DnB-Radio.com
on_press:
then:
- media_player.play_media: 'https://dnbradio.nl/dnbradio_main.mp3'
on_press:
then:
- media_player.stop
number:
icon: "mdi:volume-high"
min_value: 0
max_value: 100
step : 1
optimistic: true
restore_value: false
initial_value: 75
on_value:
then:
- media_player.volume_set: !lambda "return x/100;"
Logger output:
https://pastebin.com/vef6Vd7f
The logs that get generated if I comment out the template number section from the YAML:
https://pastebin.com/z40wY1Qr
yes i know that the SPI and I2S component fail to set up, that is because the ESP was unplugged from the peripherals when I generated the logs.
Please tell me if I can help with further Info.
EDIT
I have taken a look at the autogenerated code. It seems to me that the media player gets initialized and registered on line 350, while the the template number does not get touched until line 539. So my hunch about the uninitialized media player seems very unlikely now.
