BOOT UP errors for HASSIO version hassos_rpi3-1.13.img.gz and hassos_rpi3-64-1.13.img.gz
Hello Home Assistant community,
I am trying to install HASSIO on a Raspberry PI 3B and through several attempts using different sd cards different images, 32bit and 64bit, I receive the following messages.
I was using the Home Assistant, Installing Hass.io instructions web page to download the image, use Etcher to burn it to the sd card and then install it on the Raspberry PI. I did this four times with different sd cards and the 32bit and 64bit image. I am a noob but i’m guessing it looks like something may be wrong with the Raspberry PI.
Any help is appreciated
Problem fixed. I’m a noob. I had a conflicting sd card in the usb port
I have the same error. SSD attach on my 3B+ (no sd-card inserted)
How did you resolve that?
Unless they updated the firmware, you have to run the OS from the sd card. Without an SD card with the OS installed on it, the pi will not work.
