Booting Into Safe Mode--HELP!
I have my system make a full backup created nightly right before a nightly reboot. (running HA 2021.5.5 core)…suddenly, it reboot itself into safe mode with OODLES of errors.
I tried a full backup, it appeared to complete successfully–nothing. Re-rebooted into safe mode. Even a couple days older’s (wonderful grammar, right?..lol) reboot–nothing.
I’m at a loss here. Any suggestions?
Fix the errors starting at the first working your way down.
Unfortunately, my knowledge base cuts off at decoding several of these errors. My bigger question/misunderstanding is if it was working fine on 6/12 and rebooted fine since then, how come all of a sudden these errors are showing even after restoring that 6/12 backup?
That’s a good question, but you haven’t posted any errors. Your guess is as good as mine.
To be clear: Your question is too broad, and it doesn’t have enough information to give you an answer. The issue could literally be anything. Only you have the power to provide the information we need to help you. Start by sharing your logs.
