Hi everyone,
I am facing an issue after moving my HA image from a parity disk to my cache disk on Unraid. This worked quite easy and was done in order to not having the parity check negatively affecting the performance of HA.
fs0:
brings
'fs0:' is not a valid mapping.
I then performed the following (read in the Unraid forums):
modprobe nbd max_part=8
qemu-nbd --connect=/dev/nbd0 /path/to/the/image/ha.qcow2
mkdir /path/to/the/mount/point/
fdisk /dev/nbd0 -l
mount /dev/nbd0p1 /path/to/the/mount/point/
and the output is:
Disk /dev/nbd0: 32 GiB, 34359738368 bytes, 67108864 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: A4E33CCF-98F3-43B5-B08D-6F37CFF42D17
Device Start End Sectors Size Type
/dev/nbd0p1 2048 67583 65536 32M EFI System
/dev/nbd0p2 67584 116735 49152 24M Linux filesystem
/dev/nbd0p3 116736 641023 524288 256M Linux filesystem
/dev/nbd0p4 641024 690175 49152 24M Linux filesystem
/dev/nbd0p5 690176 1214463 524288 256M Linux filesystem
/dev/nbd0p6 1214464 1230847 16384 8M Linux filesystem
/dev/nbd0p7 1230848 1427455 196608 96M Linux filesystem
/dev/nbd0p8 1427456 67108830 65681375 31.3G Linux filesystem
So it appears to not be broken. After checking that, I unmounted and disconnected using:
umount /path/to/the/mount/point/
qemu-nbd --disconnect /dev/nbd0
rmmod nbd
Do you guys have any idea what to try without losing all the data/config? Especially ZWave is what took soooo much time.
Thanks a lot in advance guys!
