I’m guessing the update didn’t install aiohttp_cors==0.4.0
Here is what I got from the Home-assistant.log:
16-11-05 20:00:24 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:00:24 homeassistant.bootstrap: Not initializing api because not all dependencies loaded: http
16-11-05 20:00:24 homeassistant.bootstrap: Not initializing frontend because not all dependencies loaded: api
16-11-05 20:00:24 homeassistant.bootstrap: Not initializing logbook because not all dependencies loaded: frontend
16-11-05 20:00:25 homeassistant.bootstrap: Error during setup of component emulated_hue
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py", line 149, in _async_setup_component
None, component.setup, hass, config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/emulated_hue.py", line 79, in setup
trusted_networks=[]
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/http.py", line 253, in __init__
import aiohttp_cors
ImportError: No module named 'aiohttp_cors'
16-11-05 20:00:26 homeassistant.bootstrap: Not initializing media_player because not all dependencies loaded: http
16-11-05 20:00:36 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:00:36 homeassistant.bootstrap: Component http failed to setup
16-11-05 20:00:36 homeassistant.bootstrap: Unable to prepare setup for platform notify.html5 because dependency frontend could not be initialized
16-11-05 20:00:36 homeassistant.bootstrap: component notify failed to initialize
16-11-05 20:01:03 netdisco.ssdp: Found malformed XML at http://192.168.86.178:9080: status=ok
16-11-05 20:01:14 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:01:14 homeassistant.bootstrap: Component http failed to setup
16-11-05 20:01:24 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:01:24 homeassistant.bootstrap: Component http failed to setup
16-11-05 20:01:34 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:01:34 homeassistant.bootstrap: Component http failed to setup
16-11-05 20:01:44 homeassistant.bootstrap: Not initializing http because could not install dependency aiohttp_cors==0.4.0
16-11-05 20:01:44 homeassistant.bootstrap: Component http failed to setup
