Stoli
May 19, 2021, 9:19pm
1
I feel like this should be simple but it is eluding me…
Here is what I have:
Here is the simplified code:
type: vertical-stack
cards:
- type: entities
style: |
ha-card {
background: rgba(0, 0, 0, 0);
box-shadow: none;
entities:
... Entity 1, Entity 2 ...
- type: horizontal-stack
cards:
... Sun, Mon, Tue ...
show_header_toggle: false
title: Card 1
Here is what I want it to look like:
Can’t seem to get there.
In a nutshell, I want it to look like all my cards are grouped together in a single card.
Stoli
May 19, 2021, 9:39pm
3
I think I tried that and several other card types but I couldn’t figure out how to get the border around it all. It seems to me that all those types of custom cards are ways of organizing the cards that you put in them, but getting a border around the whole group is what I can’t figure out.
tom_l
May 19, 2021, 11:27pm
4
Don’t use a vertical stack card. Use an entities card with the custom:hui-element card.
card_mod:
class: top-level-card
entities:
- entity: switch.zone_3
type: 'custom:multiple-entity-row'
toggle: true
state_color: true
entities:
- entity: binary_sensor.zone_3_day_active
- entity: sensor.zone_3_time_remaining
- entity: automation.irrigation_zone_3_am
name: Enable AM Schedule
toggle: true
state_color: true
entities:
- entity: input_datetime.zone_3_am_on_time
- entity: input_number.zone_3_run_time
- entity: automation.irrigation_zone_3_pm
name: Enable PM Schedule
toggle: true
state_color: true
entities:
- entity: input_datetime.zone_3_pm_on_time
- card_type: horizontal-stack
cards:
- entity: input_boolean.zone_3_mon
template: day_button
type: 'custom:button-card'
- entity: input_boolean.zone_3_tue
- entity: input_boolean.zone_3_wed
- entity: input_boolean.zone_3_thu
- entity: input_boolean.zone_3_fri
- entity: input_boolean.zone_3_sat
- entity: input_boolean.zone_3_sun
type: 'custom:hui-element'
title: Garden Beds
type: entities
Stoli
May 20, 2021, 1:45pm
5
Thank you!!! That was exactly what I was looking for.
As with most HA issues I have had, when I find the answer to one question, 3 more pop up. Care to share your “day_button” template? I think I know the code but trying to clean things up and figure out how to implement it like you have (i.e. where to put it and in what format). Right now, I have:
- entity: input_boolean.zone_1_mon
styles:
card:
- font-size: 12px
state:
- icon: 'mdi:cancel'
value: 'off'
- icon: 'mdi:check-circle'
styles:
card:
- box-shadow: 0 0 4px 2px var(--paper-item-icon-active-color)
value: 'on'
tom_l
May 20, 2021, 1:57pm
6
day_button:
color_type: icon
hold_action:
action: none
show_label: false
show_name: true
show_state: false
state:
- icon: 'mdi:checkbox-marked-circle'
styles:
card:
- border: solid 1px var(--paper-item-icon-active-color)
- box-shadow: 0px 0px 10px 3px var(--paper-item-icon-active-color)
name:
- color: var(--primary-text-color)
value: 'on'
styles: null
value: 'off'
styles:
card:
- border-radius: 10px
- border: solid 1px var(--primary-color)
- box-shadow: none
- padding: 6px 0px
- margin: 0px 0px
- '--ha-card-background': 'rgba(0, 0, 0, 0)'
grid:
- grid-template-areas: '"i" "n"'
- grid-template-rows: 33% auto
- grid-template-columns: auto
icon:
- width: 28px
name:
- justify-self: middle
- align-self: end
- font-size: 14px
- padding: 0px 0px
- color: var(--secondary-text-color)
tap_action:
action: toggle
Stoli
May 21, 2021, 2:24pm
7
Thanks again.
The posts on your irrigation system have been extremely helpful. Saved me tons of time.
What type of controller do you use to control the sprinkler valves?
tom_l
May 21, 2021, 2:26pm
8
An ESP32 mini board running ESPHome and a few relay modules driving 24VAC garden irrigation valves you can buy at any hardware store.
The 24VAC plug pack to drive the valves is pretty much universally available too.
EDIT:
EspHome config:
esphome:
platform: ESP32
board: mhetesp32minikit
wifi:
ssid: 'WAPRU'
password: !secret wifi_pwd
manual_ip:
static_ip: 10.1.1.89
gateway: 10.1.1.1
subnet: 255.255.255.0
api:
password: !secret api_password
logger:
level: WARN
ota:
password: !secret esp_pwd
esp32_ble_tracker:
scan_parameters:
active: false
- platform: wifi_signal
name: "Irrigation WiFi Signal"
update_interval: 4s
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
send_first_at: 1
- platform: xiaomi_hhccjcy01
mac_address: 'C4:7C:8D:6B:12:1F'
temperature:
name: "Lawn Temperature"
moisture:
name: "Lawn Moisture"
illuminance:
name: "Lawn Illuminance"
conductivity:
name: "Lawn Soil Conductivity"
# battery_level:
# name: "Lawn Battery Level"
- platform: ble_rssi
mac_address: C4:7C:8D:6B:12:1F
name: "Moisture Sensor RSSI"
icon: mdi:bluetooth
filters:
window_size: 15
send_every: 15
send_first_at: 1
binary_sensor:
- platform: status
switch:
- platform: gpio
pin:
number: GPIO17
icon: mdi:sprinkler
- platform: gpio
pin:
number: GPIO27
icon: mdi:sprinkler
- platform: gpio
pin:
number: GPIO32
icon: mdi:sprinkler
- platform: restart
Stoli
May 21, 2021, 3:00pm
9
Yeah, I have a similar setup in the works. WEMOS D1 Mini driving 5 relays. Was trying to figure out a good failsafe in case HA crashed with a valve on and I was out of town. Think I just figured it out. The D1 is flashed with Tasmota and I think I can set a timeout on each relay using the pulsetime command. Need to do some testing to make sure.
Haven’t explored ESPHome yet. Most of my nodes are either Tasmota or custom firmware using MQTT.
Stoli
May 21, 2021, 3:22pm
10
Has that xiaomi sensor (MiFlora?) been reliable and useful?
tom_l
May 22, 2021, 2:48am
11
Reliable?
No, not until I hacked it out of its case and put it in another waterproof box with more batteries and a larger antenna .
Since then it has been perfectly reliable.
And yeah it has been useful. It prevents my irrigation cycles running if the lawn moisture content is above 40%. A value I came to by trial and error that is highly dependant on where and how it is stabbed into the lawn.
ducsky12
(Ducsky12)
August 16, 2021, 9:29am
12
Hi tom_I. Very like your card. I’m newbie and don’t understand how to do this. Can you share the code of several entities:
binary_sensor.zone_3_day_active,
sensor.zone_3_time_remaining,
automation.irrigation_zone_3_am,
input_datetime.zone_3_am_on_time,
input_number.zone_3_run_time,
Thanks you so much!
tom_l
August 16, 2021, 9:34am
13
It is all available in this topic:
Hello everyone! I just created my first project for my Home Assistant instance.
This is a sprinkler controller system based on a NodeMCU board that allows for virtually limitless amount of control zones.
Check out my GitHub repo and let me know what you guys think.
ducsky12
(Ducsky12)
August 16, 2021, 2:26pm
14
Thanks for your share! It worked fine.
hi,
probably a newbie question, but I am trying to replicate this solution but I don’t know where to put this “template code”? in the dashboard yaml file? if so, where exactly?
thanks
Christian
Stoli
January 8, 2023, 1:19pm
16
I’m no expert, so there could be a more appropriate location, but it worked when I did this:
Home Screen
Click 3 vertical dots and select “Edit Dashboard”
Click 3 vertical dots and select “Raw configuration editor”
Paste the template code at the end
