Has anyone gotten the [Adafruit breakout of the] BMP388 sensor working in ESPHome?
Thought I’d check before doing a Custom Sensor. (the result of which, if I’m successful, I’ll post here later.
Hello, were you able to get this going via ESPHome?
I did, and forgot to post my code as promised.
But I’m pretty sure that it now has its own integrated module.
If not, comment here and I’ll post my code.
I see in my own config that I’ve transitioned to the built-in 388 component, using this in my YAML config:
- platform: bmp3xx
temperature:
name: "${node_name} BMP388 Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
accuracy_decimals: 1
pressure:
name: "${node_name} BMP388 Pressure"
accuracy_decimals: 2
I am, obviously, translating it to degrees Fahrenheit in the sensor. Chop that part if you live in a country that has sanely chosen to use degrees Celsius/Centigrade.
