Hello all,
I am trying to solve heating issue in my flat…
I have 5 heating modules; and running Junkers Condens. Currently there is only EasyControl CT 200 controlling solution which has multiple issues:
The most critical is that temp is captured directly on the remote controlled valves. Temp around these valves is different as the one in the middle of the room, the sun can directly shine on the valve, or the air circulating between window frame can make it colder etc.
The mentioned solution doesnt support external temp. sensors to link it, and to use to capture rooms temp.
I was told that solution is using some “modulation” ie its connected directly to the Heater bus, and its more optimal as Turning it On/Off.
Any idea how can one achieve/setup modern / working heating solution?
Thank you!
Junkers Bosch Condens 5300i WM, GC5300iWM 24/100S 23, Erdgas E/H
https://www.heizungsdiscount24.de/gas-heizung/junkers-bosch-condens-5300i-wm-gc5300iwm-24100s-23-erdgas-eh.html
Junkers Bosch Regler EasyControl CT 200
https://www.heizungsdiscount24.de/regelungstechnik/junkers-bosch-regler-easycontrol-ct-200-weiss-set-mit-3-funk-thermostaten.html
