Bosch home-connect stopped working
Hi all,
I need some help to fix the home-connect integration on my envirorment.
For the last couple of days it seems that although it recognizes the appliance it fails to control it.
Ive deleted and re-added the integration with no issues or errors. The appliance and its entities are recognized.
The appliance can be controlled from the home-connect android app with no issues.
There are several errors on the log.
Any thoughts?
Thank you.
Logger: homeconnect.sseclient
Source: /usr/local/lib/python3.9/site-packages/homeconnect/sseclient.py:89
First occurred: 10:22:03 AM (1 occurrences)
Last logged: 10:22:03 AM
Exception while reading event:
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 441, in _error_catcher
    yield
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 767, in read_chunked
    self._update_chunk_length()
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 697, in _update_chunk_length
    line = self._fp.fp.readline()
  File "/usr/local/lib/python3.9/socket.py", line 704, in readinto
    return self._sock.recv_into(b)
  File "/usr/local/lib/python3.9/ssl.py", line 1241, in recv_into
    return self.read(nbytes, buffer)
  File "/usr/local/lib/python3.9/ssl.py", line 1099, in read
    return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 760, in generate
    for chunk in self.raw.stream(chunk_size, decode_content=True):
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 575, in stream
    for line in self.read_chunked(amt, decode_content=decode_content):
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 796, in read_chunked
    self._original_response.close()
  File "/usr/local/lib/python3.9/contextlib.py", line 137, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 446, in _error_catcher
    raise ReadTimeoutError(self._pool, None, "Read timed out.")
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='api.home-connect.com', port=443): Read timed out.
  File "/usr/local/lib/python3.9/site-packages/homeconnect/sseclient.py", line 81, in __next__
    next_chunk = next(self.resp_iterator)
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 767, in generate
    raise ConnectionError(e)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.home-connect.com', port=443): Read timed out.
Logger: homeassistant.helpers.service
Source: helpers/service.py:130
First occurred: 10:21:24 AM (2 occurrences)
Last logged: 11:35:57 AM
Unable to find referenced entities light.hood_light
