Bosch Relais impuls
I am using home Assistant on a Synology and I would like to control a power outlet with a Bosch smart home Relais (integrated via ziggbee2mqtt) by a button.
but I cannot configure the Relais on the GUI to the Impulse mode.
With my button the Relais is only closing the circuit while button is pressed.
It should work like pressing the button once, circuit is closed, pressing the button again, circuit is open.
Any idea?
Create a button, edit tap behavior, select action, search for switch: toggle, add your bosch switch.
