For triggering all smoke detectors, I dont know if this is possible. I guess we’ve to test this, maybe the intrusion detection could be set to alarm mode with an external trigger.
You can file an issue in the official Bosch API repo, perhaps someone has an idea.
it took me some time, but with the latest version, the universal switch buttons are now added as input events. You’re now able to create automations based on the two states for both buttons.
Breaking change: I had to move the bosch_shc codebase within the repository to the subfolder custom_components. The next time you will pull from my repository, please be aware of this!
This comes along with good news: I moved forward adding HACS custom support to the repository. This should ease the pain with updating the custom component in the future. If you are already using HACS, you can follow this guide on how to include custom repositories in the HACS community store.
Going to HACS is good news! Thanks Thomas. I am just wondering on how to transition from my custom component (with everything set up nicely) to HACS without loosing everything I have done until now…
But I actually wanted to ask about something else today.
I realized that Motion sensors from the bosch integration acts different to others from Hue, or my Ring etc.
When creating automations I can use “Device” for Hue and other sensors, but not for Bosch, since these do not have triggers set I can use. Is this something I can overcome somehow? I think it would make using them in automations a lot more easy.
@kai-seipp You don’t have to be afraid, the only thing which changes is the content of the custom_component/bosch_shc folder. Configuration will stay the same.
I did it the following way: I deleted the bosch_shc-Folder in the custom_component folder, then added the boschshc-hass repository as custom repository like described in the link above. You can then select the component for installation and will have to restart HA afterwars. That was everything I had to do.
For motion sensors, we would need to register events from motion sensor in HA. I’ve done this recently for the universal switches, so it should not be too complicated to add this for motion sensors as well. I’ll have a look the next days.
is it possible that there is a bug in the thermostat integration?
I played around with service calls today to find out how to automate them and it seemed a bit inconsistent. It worked in general, but the service call climate.set_temperature did not work for me as expected.
should switch the thermostat into heat mode which is translated to the manual mode Bosch (finger icon in the app - meaning that no schedule will be applied).
In my case it will change the temperature but stay in auto mode.
I have to execute it in 2 commands to get the expected result: first set hvac_mode to heat and then call set_temperature.
Did you already try out? If not, maybe you’ll wait for some more days, as I will have to rename the trigger event. I just learned that a platform only supports one platform event so I will put together all SHC events in one event type.
I‘ll inform on this once it is finished.
UPDATE:
All bosch_shc events are consolidated as bosch_shc.event trigger events. With this change, it is possible to create automation triggers directly from the device list. Devices which provide events are:
WRC2: Universal Switch devices, for upper/lower button pressed short/long
MD: Motion Detector devices, if a motion event is detected
SHC: All scenarios registered in the official Bosch Smart Home app, if the scenario is triggered.
This will invalidate previous events. Sorry for any inconvenience.
/UPDATE
What do I have to do to make this work? I just updated to the latest version from https://github.com/tschamm/boschshc-hass but I don’t see humidity in my climate entities.
what kind of device is BWTH? Is it the wall thermostats?
It would be of great help, if you could make a listing of the device services provided via postman. If you need tips how to do that, write me a PM.
EDIT: Please double check if these are Bosch devices and not Homematic IP. The latter are not supported via Bosch SHC.
thanks a lot for your quick reply. I have the wall thermostat for floor heating (230V). It seems the BWTH devices are actually child devices of the ROOM_CLIMATE_CONTROL devices. Their ID indicates HomematicIP, so are they not supported?
Here is one of these devices as returned via Postman:
support for BWTH is added with the new bosch_shc version I just pushed to github. You won’t see humidity in the climate platform, instead you’ll have additional sensor entities for temperature and humidity of each BWTH device.
Is the information provided in the Thermostat service of relevance for you? As I don’t own these devices, I cannot add the missing services.
thanks so much. I actually just finished writing a small script pulling the humidity levels using your library, which was a fun exercise, so also thanks a lot for providing this awesome library. Of course I’ll update the component asap and check it out/use that instead of my script. Temperature works fine via the climate_control itself but I’ll check if there is anything relevant in the Thermostat service.
Again, thanks a lot for your work. It is much appreciated.
