Bought the HA Yellow version3.0, installed RPI CM4, connected to the router LAN, HA not getting IP, help
Hello.
As a result, I went to the GUI of my router and checked whether any new device has requested the IP address , and I have not found any new device out there…So, simply as it is in the subject - I can’t get the HA to work for me, it does not accept the IP . Please help, what to do next.
Please see the photo (top left corner - my home router, right hand side - HA, left bottom - power supply):
https://yellow.home-assistant.io/guides/use-serial-console-windows/
I have reviewed the manual ( Getting Started – Home Assistant Yellow ) more closely and understood that the OS has to be installed.
I thought it was “all OOTB already there, and I need to only deploy the CM4 on it, which is obviously not…”
After I have followed the Getting Started – Home Assistant Yellow
I was able to flush the OS onto USB, plug in the USB, wait for some time, and got it all working.
