Hi All,
i have a switch that receive is_state from a sensor.file
now when i turn on or turn off the switch it bounce and after a few seconds it return to the right state
i tried to do the following:
when you change the switch to turn on write on to a the sensor.file then turn on the device everything worked great but the button is still bouncing from on to off wait a few seconds then understand that the state should be on then it change state this is really annoying and i don’t know how to fix it
is there a way that i can tell him not to change the state before he check the last line of the file ?
can i increase the sensor.file interval speed so it will work the second i change the file
is there a better solution to this issue then the one that i am trying ?
Thanks for your help
