Box RTL Tube - or anything like it?
Hi there,
I have an exterior motorized blind that I’m not able to connect to anything - so, it seems. Its remote control is here:
I’m assuming that the brand for the controller is Tube, as there is something called “Box RTL Tube” that claims it controls my blinds… but I’m nowhere near finding the way to integrate it to HA.
Does anyone here know these blinds? Or its controller, in this case??
Looking at the specifications for the Sonoff DualR3, it seems that my blind does not have enough wires (sorry for my basic explanation) to accept the Sonoff switch, and it would seem that my only chance is the remote.
Any other suggestion??
Thank you in advance.
Cheers!
MO
Looks like an RF remote - you could use a universal remote like Broadlink RM4 Pro.
With a rolling code that stops me from being able to “copy” it… :frowning:
Hi! Were you able to fix this? I have the same problem. I tried with RM4Pro with no luck.
Thanks!!
My remote lloks the same from behind. I installed roller blinds with hunter douglas some years ago.
I tried the RM4 Pro and the Bond bridge with no luck. Probably because of the rolling codes that were mentioned.
Its driving me crazy. Box RTL and the Somfy myLink sound promising depending in the mogor you have, but have not tried them myself.
It seems that, what it is used, is a Lianda RTL RF connection. Here is a little more info: Lianda RTL Blinds - #10 by santiagolarrain - Shades & Blinds - Bond Home Forum
