BP - Lutron Caseta Pico Paddle Remote Button Actions
I finally was able to sit down and take another look at my previous pico paddle blueprint. Based off of the previous blueprint I had immense trouble editing it to do double clicks and long presses. So I instead I based this edit off of GregTR’s extremely talented blueprints, and just tailored it for use with the new Lutron Pico Paddle Remote.
Let me know how it works for you(, I only have my own testing of actions to base it’s functionality).
blueprint:
  name: BP - Lutron Caseta Pico Paddle Remote Button Actions
  description: Different Actions on Short, Long, and Double Click button presses.
  domain: automation
  input:
    pico_id:
      description: The Lutron Pico used to trigger the automations
      selector:
        device:
          model: PJ2-1P-GXX (PaddleSwitchPico)
          multiple: false
    short_click_action_on:
      name: On Button Short Click
      description: The action(s) to launch for a single short click
      default: []
      selector:
        action: {}
    short_click_action_off:
      name: Off Button Short Click
      default: []
      selector:
        action: {}
    long_click_action_on:
      name: On Button Long Click
      description: The action(s) to launch for a long click
      default: []
      selector:
        action: {}
    long_click_action_off:
      name: Off Button Long Click
      default: []
      selector:
        action: {}
    double_click_action_on:
      name: On Button Double Click
      description: The action(s) to launch for a double click
      default: []
      selector:
        action: {}
    double_click_action_off:
      name: Off Button Double Click
      default: []
      selector:
        action: {}
    delay_click:
      name: Double Click Delay
      description: The time in milliseconds used for the double click detection
      default: 250
      selector:
        number:
          min: 100.0
          max: 1000.0
          unit_of_measurement: milliseconds
          step: 1.0
          mode: slider
    delay_hold:
      description: The time in milliseconds used for the hold detection
      default: 1000
      selector:
        number:
          min: 1000.0
          max: 4000.0
          step: 1.0
          mode: slider
  source_url: https://community.home-assistant.io/t/bp-lutron-caseta-pico-paddle-remote-button-actions/719285
- platform: event
  event_type: lutron_caseta_button_event
  event_data:
    device_id: !input pico_id
    leap_button_number: 0
    action: press
- platform: event
  event_data:
    leap_button_number: 2
    action: press
- variables:
    hold_ms: !input delay_hold
    tap_ms: !input delay_click
    pico_id: '{{ trigger.event.data.device_id }}'
- choose:
  - conditions:
    - condition: trigger
    sequence:
    - wait_for_trigger:
      - platform: event
        event_data:
          action: release
      timeout:
        milliseconds: '{{ hold_ms }}'
    - choose:
      - conditions:
        - condition: template
          value_template: '{{ wait.trigger == none }}'
        sequence: !input long_click_action_on
      default:
      - wait_for_trigger:
        - platform: event
          event_data:
            action: press
        timeout:
          milliseconds: '{{ tap_ms }}'
      - choose:
        - conditions:
          sequence: !input short_click_action_on
        default: !input double_click_action_on
  - conditions:
    sequence:
    - wait_for_trigger:
      - platform: event
        event_data:
          action: release
      timeout:
    - choose:
      - conditions:
        sequence: !input long_click_action_off
      default:
      - wait_for_trigger:
        - platform: event
          event_data:
            action: press
        timeout:
      - choose:
        - conditions:
          sequence: !input short_click_action_off
        default: !input double_click_action_off
mode: single
This looks good! I had made one of my own for this remote, but yours is better, so I’ve switched to it. However, I was getting errors on startup like the following. (The automation still ran fine.)
ERROR (MainThread) [homeassistant.components.lutron_caseta.device_trigger] Cannot validate trigger {‘platform’: ‘device’, ‘device_id’: ‘xxxx’, ‘domain’: ‘lutron_caseta’, ‘type’: ‘release’, ‘subtype’: ‘on’} because subtype on is invalid
Per this comment, I modified the script to switch from device triggers to event triggers. (As an aside, the issue associated with that comment is not exactly the same as my error. And it seems to have been resolved anyway, so I’m not sure why I’m getting that error. Perhaps it’s a bug with the Lutron Caséta bug core integration that I should reported…) Anyway, here’s my modified version of your script in case anyone is having the same errors.
blueprint:
  domain: automation
  input:
    pico_id:
      selector:
        device:
          multiple: false
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
      default: []
      selector:
        action: {}
    delay_click:
      default: 250
      selector:
        number:
          min: 100.0
          max: 1000.0
          step: 1.0
          mode: slider
    delay_hold:
      default: 1000
      selector:
        number:
          min: 1000.0
          max: 4000.0
          step: 1.0
          mode: slider
- platform: event
  event_data:
    action: press
- platform: event
  event_data:
    action: press
- variables:
- choose:
  - conditions:
    sequence:
    - wait_for_trigger:
      - platform: event
        event_data:
          action: release
      timeout:
    - choose:
      - conditions:
      default:
      - wait_for_trigger:
        - platform: event
          event_data:
            action: press
        timeout:
      - choose:
        - conditions:
  - conditions:
    sequence:
    - wait_for_trigger:
      - platform: event
        event_data:
          action: release
      timeout:
    - choose:
      - conditions:
      default:
      - wait_for_trigger:
        - platform: event
          event_data:
            action: press
        timeout:
      - choose:
        - conditions:
mode: single
Thanks for this! I will have to try it out once i install my Caseta switches.
I don’t know if it’s just me, but I can only get short click on and short click off to work. Long click and double click don’t do anything for me.
Thanks,
Roy
Huh Weird re-importing the BP and doing it again seems to have fixed it?
Any change to update this with the 2025.3 update? I tried the “taking control” option and it seems to break the script.
Instead of Button 0/2 Its now “On” and “Off” so it shouldnt be too aweful to get it updated?
I have been having the same problem on and off with the past few updates. I’d only gotten it to work by rolling back to a core update that had previously worked.
But, re-importing the blueprint worked for me! Thanks! Now my wife can stop bugging me that the lightswitch is broken every time I update :sweat_smile:
Same issue here and a reimport also fixed it for me.
