Need brainstorming on ideas on how to handle please,…
Setting up some Sengled RGB Zigbee smart lights on my front porch lights.
Home Assistant (via GoControl HUSBZB-1 Zigbee) can only control ON/OFF. No controls for color or brightness. (Similar Hue bulbs are compatible with HA, but are 5x more expensive. Not worth it to me.)
Amazon Echo Plus Zigbee hub can control all aspects - on/off/color/brightness. Great. I can deal with not having color control in HA. It will just be an extra hassle to set up in Alexa.
These new RGB lights are in a circuit that is currently controlled by a Lutron Caseta smart dimmer wall switch. The Lutron switch works without a neutral. I’ve got it configured to only turn ON/OFF (no dimming).
The problem I need help with is:
When the Lutron wall switch is off, the new RGB bulbs flicker occasionally. Pretty sure it’s a result of the tiny bit of electricity that still flows due to the nature of the no-neutral smart switch.
The only fixes I can think of:
- Replace the lutron smart switch with a traditional (non-smart) light switch. The front porch lights are currently on a lutron schedule and are rarely turned on/off manually. Set up an Alexa schedule. But if the light switch is turned off with that physical switch, can no longer control them remotely.
- Change the switch to a 4 wire smart switch (not possible without $$$$). Not worth it.
- Some sort of NodeRed logic in HA that, when the Lutron switch is turned off,… turns it back on so that the RGB can be turned off with Zigbee? How to turn back on?
- Put in a “smart wall switch” that doesn’t connect to lights directly,… only serves as a signal to HA to control the RGB via Zigbee? Hard wire the RGB so that it always has power. (anyone that buys my house in the future is going to curse me).
- I think Wifi switches will have the same problem.
Any thoughts would be appreciated.
