Brand-new Home Assistant Green going directly to login screen
I just got my home-assistant green yesterday, and am trying to set it up today. New to home-automation.
After booting up, I tried to access http://homeassistant.local:8123, but that didnt connect.
After some digging around, I found the IP, and am able to connect to HA and see the screen. However, I was expecting to see the usual “Create Account” screen. Instead I just see the login screen, not sure why.
I did also order the skyconnect which I plugged in from the get-go at the time of first boot - not sure if that messed something up. I’ve removed it now, and restarted HA.
However, still the same issue.
Appreciate any tips on how to get back to the new user account page.
Thanks.
Figured it out after digging around a little.
Had a microsd card lying around, so was able to reset it using the instructions here - Resetting the device – Home Assistant Green
