I just spun up another new, clean VM running Home Assistant and enable Z-Wave. Started the Z-Wave controller/network. It imports all the nodes, but no entities. The log does not show any errors from what I can tell. It seems to go through importing the nodes, and then queries each node for its capabilities, which the nodes return. Here’s an example of a node’s response:
2019-07-22 15:06:06.115 Info, Node003, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=3): 0x01, 0x04, 0x00, 0x41, 0x03, 0xb9
2019-07-22 15:06:06.127 Detail, Node003, Received: 0x01, 0x09, 0x01, 0x41, 0xd3, 0x9c, 0x01, 0x04, 0x11, 0x08, 0xe5
2019-07-22 15:06:06.127 Info, Node003, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2019-07-22 15:06:06.127 Info, Node003, Protocol Info for Node 3:
2019-07-22 15:06:06.127 Info, Node003, Listening = true
2019-07-22 15:06:06.127 Info, Node003, Beaming = true
2019-07-22 15:06:06.127 Info, Node003, Routing = true
2019-07-22 15:06:06.127 Info, Node003, Max Baud Rate = 40000
2019-07-22 15:06:06.127 Info, Node003, Version = 4
2019-07-22 15:06:06.127 Info, Node003, Security = false
2019-07-22 15:06:06.127 Info, Node003, Basic device class (0x04) - Routing Slave
2019-07-22 15:06:06.127 Info, Node003, Generic device Class (0x11) - Multilevel Switch
2019-07-22 15:06:06.127 Info, Node003, No specific device class defined
2019-07-22 15:06:06.127 Info, Node003, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_SWITCH_MULTILEVEL
2019-07-22 15:06:06.127 Info, Node003, Mandatory Command Classes for Node 3:
2019-07-22 15:06:06.127 Info, Node003, COMMAND_CLASS_SWITCH_MULTILEVEL
2019-07-22 15:06:06.127 Info, Node003, Mandatory Command Classes controlled by Node 3:
2019-07-22 15:06:06.127 Info, Node003, None
2019-07-22 15:06:06.127 Detail, Node156, Expected reply was received
2019-07-22 15:06:06.127 Detail, Node156, Message transaction complete
2019-07-22 15:06:06.127 Detail, Node003, Removing current message
2019-07-22 15:06:06.127 Detail, Node003, Notification: NodeProtocolInfo
2019-07-22 15:06:06.128 Detail, Node003, Notification: ValueAdded
2019-07-22 15:06:06.129 Detail, Node003, Notification: ValueAdded
2019-07-22 15:06:06.130 Detail, Node003, Notification: ValueAdded
2019-07-22 15:06:06.130 Detail, Node003, Query Stage Complete (ProtocolInfo)
2019-07-22 15:06:06.130 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2019-07-22 15:06:06.130 Detail, Node003, QueryStage_Probe
2019-07-22 15:06:06.130 Info, Node003, NoOperation::Set - Routing=true
2019-07-22 15:06:06.131 Detail, Node003, Queuing (NoOp) NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xca
2019-07-22 15:06:06.131 Detail, Node003, Queuing (Query) Query Stage Complete (Probe)
2019-07-22 15:06:06.131 Info, Node003, Sending (NoOp) message (Callback ID=0x0b, Expected Reply=0x13) - NoOperation_Set (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xca
2019-07-22 15:06:06.145 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-22 15:06:06.145 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-22 15:06:06.188 Detail, Node003, Received: 0x01, 0x05, 0x00, 0x13, 0x0b, 0x00, 0xe2
2019-07-22 15:06:06.188 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2019-07-22 15:06:06.188 Info, Node003, Request RTT 57 Average Request RTT 57
2019-07-22 15:06:06.188 Detail, Expected callbackId was received
2019-07-22 15:06:06.188 Detail, Expected reply was received
2019-07-22 15:06:06.188 Detail, Message transaction complete
2019-07-22 15:06:06.188 Detail, Node003, Removing current message
2019-07-22 15:06:06.188 Detail, Node003, Notification: Notification - NoOperation
I do have several of these messages at the end of the log:
2019-07-22 15:21:04.244 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2019-07-22 15:21:04.245 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
