Braun ThermoScan / ExactFit over BLE, looking for testers
I’m building a local integration for Braun connected health devices, without the Braun app or account. It talks BLE directly, through the HA adapter or an ESPHome proxy, and pairs in the config flow with the PIN shown on the device.
Each reading can be attributed to a person (phone notification or a button). Today it works with the ThermoScan 7+ Connect (IRT6575). The ExactFit 5 Connect (BUA6350) blood pressure monitor is experimental, and the ThermoScan 4 Connect (IRT3575) is still untested.
I’m desperately looking for people with Braun BLE devices to test it and help add more models :slight_smile: Any report helps. The contributing guide explains how to capture what a device sends, and I also will be happy to help or assist if needed.
Braun Health BLE for Home Assistant (HACS custom repository)
Regards,
I would like to contribute my experience; I have an IRT6575.
Today I installed the integration, and it worked just as you described in the readme.
To be honest, the decision to buy this model is greatly influenced by the mere fact you’re working on this integration! I thank you for your work! :folded_hands:
Thanks a lot for your feedback! I’m really happy it’s useful to someone else and that it works for you too.
Since yours is a second IRT6575, it would help me a lot to know a bit more about your setup, so I can add it to the list of confirmed devices:
  • the firmware and model number shown by the diagnostic sensors on the device page
  • your Home Assistant version, and whether the thermometer connects through an ESPHome Bluetooth proxy or a local adapter
And if anything looks odd, don’t hesitate to report it here or open an issue on GitHub.
Thanks again!
Thanks so much for this, I just bought an IRT6575 and it works perfect out of the box- the notification prompting is exactly the kind of thing I was looking for!
My only feedback is it would be nice to be able to change the unit to F for the notification details, as currently it’s always in C, and it would be nice to be able to link to an HA user in the initial onboarding workflow (or if that’s a technical limitation, just add a note saying you can do it after, so you don’t have to create and then delete the user if you end up wanting to link them).
In case you’re still looking for the details, I just updated HA to be able to use this so I’m on 2026.10.5, and I’m using an ESPHome Bluetooth proxy (via wired Ethernet). Using a local Bluetooth adapter never worked consistently for me in HA.
The thermometer reported firmware is 1.2.0 and the model is TS7+.
Thanks a lot for the details and the feedback, both were really useful!
Your thermometer matches mine exactly (TS7+, firmware 1.2.0, through an ESPHome proxy), so I’ve added it to the device notes as a second confirmed unit. Same experience here on the Bluetooth side, by the way: an adapter plugged straight into HA was never reliable for me, while the ESPHome proxies just work.
Both suggestions are in v0.1.18:
  • Notification texts now follow your Home Assistant unit system, so they show °F when your server is set to imperial. The sensors themselves already converted, only the texts we write were stuck in °C. Being European, Fahrenheit simply never crossed my mind, so thanks for keeping me honest. 98.6 is a perfectly normal number now, I promise!
  • The setup now has a “Home Assistant people” field: each person you pick is added and linked to their Home Assistant person straight away. The free-text names are still there for people without an account, like kids or guests.
Let me know if anything looks off after updating.
Good news, it’s now in the HACS default list, so you can just search for “Braun Health BLE”, no more custom repository. And just in time for 2026.11, where HACS gets built into HA as the Marketplace :grinning_face_with_smiling_eyes:
I just bought a new ThermoScan 7 Connect+ and would like to set it up.
Does this only work with a separate BLE interface, or can I also use my phone’s BLE to send the data to the server via the Home Assistant app?
Hi, congrats on the new thermometer!
Unfortunately the phone won’t work for this. The HA companion app can’t relay Bluetooth devices to Home Assistant. You need Bluetooth on the Home Assistant side, either an adapter on the HA machine or an ESPHome Bluetooth proxy.
I’d go with the proxy, an ESP32 board costs a few euros and you can flash it from the ESPHome web installer in a couple of minutes. Just make sure it runs as an active proxy, since the integration connects to the thermometer to read the measurements. Local adapters plugged into HA have been flaky for me, while the proxies just work.
Once that’s set up, HA should discover the thermometer by itself when you turn it on.
Thank you very much for the feedback.
I followed your instructions exactly, and it works. Great job!!!
