So I noticed that my LED dimming automations stopped working recently, although I can’t say for sure which month’s release might be the culprit, and I hope someone here can help me understand why.
I have zwave dimmer switches that control various LEDs (e.g., under counter lighting, behind mirror lighting, etc.). The Zwave switch doesn’t directly control the load, it’s just providing Zwave central scene events that act as automation triggers. The actual LED control is handled by a wireless DMX decoder & multichannel LED driver. To replicate a “hold to dim” or “hold to brighten” effect when interacting with the zwave switch, I long ago set up and have enjoyed success with the following set of automations and scripts.
Automation “Dim Start” watches for a central scene event for KeyHeldDown. In response, the automation calls a script “dim”
The “dim” script does three things: (i) it reads the current brightness attribute, and if it’s above a minimum threshold, (ii) reduces it by a fixed step amount, and then (iii) calls the “dim pause” script.
The “dim pause” script does two things: (i) delay 50ms and (ii) call the “dim script”
To prevent this cycle from continuing forever, there is another automation “Dim Stop” that watches for a central scene event of KeyReleased, and in response sends “off” commands to both “dim” and “dim pause” scripts.
This worked wonderfully well for a long time. Recently, I’ve noticed that holding down the switch doesn’t work anymore, and upon investigation, see that the log includes the error “dim_pause: Already running”
I can’t see how that would be - the “dim_pause” script delays 50ms, and then calls “dim,” and should at that point no longer be busy, so that when “dim” calls “dim_pause” again, the cycle repeats.
Below is the relevant code:
Automation to start dimming:
alias: Counters dim start
description: Dims the counters LED strip based on switch held down
- platform: event
event_type: zwave_js_value_notification
event_data:
node_id: 122
property_key: "002"
value: KeyHeldDown
condition: []
- service: script.turn_on
entity_id: script.counters_dim
mode: single
Script to actually dim:
sequence:
- condition: "{{ (state_attr('light.kitchen_counters', 'brightness')|int) > 10 }}"
- service: light.turn_on
data_template:
entity_id: light.kitchen_counters
brightness: >-
{% set current =
states.light.kitchen_counters.attributes.brightness|default(0)|int %} {%
set step = 5 %} {% set next = current - step %} {% if next < 10 %}
{% set next = 10 %}
{% endif %} {{ next }}
entity_id: script.counters_dim_pause
Script to pause before dimming again:
sequence:
- delay:
milliseconds: 50
Automation to stop dimming when keypad on switch released:
alias: Counters dim stop
description: Stops dimming the counters LED strip based on down switch released
- platform: event
event_data:
node_id: 122
property_key: "002"
value: KeyReleased
condition: []
- service: script.turn_off
mode: single
