Bresser Weather Station: Interest in local only integration - anybody?
Hi there,
I recently integrated my Breather Weather Station 7-in-1 (7003510) including the outdoor sensors (Wind, Temperature, Humidity, Wind, Rain, Solar) and three additional indoor sensors (hygrometers: temperature + humidity) in Home Assistant without the need for any external services (awekas in my case).
Initially my weather station was talking to awekas.at and I fetched the data using a RESTful sensor. This worked fine. However my goal was to get completely independent and use my sensor data directly in HA (without the need to send it to an external service first).
So I did the following:
  • analyzed the data/requests which my weather station sent to awekas.at
  • wrote a small dummy server in ruby which accepts and caches the requests and the data
  • added another REST service to that ruby server which delivers the latest cached data as JSON, identical to that what awekas.at delivers
  • put this ruby server into a local HA add-on
  • changed the URL of my initial RESTful sensors from awekas to the URL of my local ruby server (the add-on) which polls the server every 30s.
  • changed the URL of my weatherstation from awekas to my HA IP (the add-on server)
This has been in use now for about 8 weeks without any problems. But I would consider it as PoC:
  • the add-on’s name is still hello world, as it was mentioned in the add-on tutorial (i started with that)
  • the code is lacks error handling at some places
  • it does not offer much configuration options (e.g. it converts all values to Celsius and metric scales, the port numbers are fixed, etc)
  • the http server is not a “real” one, it is just a TCP/IP server faking a HTTP server
However, it works for me with very few lines of code and I have a 100% local solution.
So here my question:
Is there any interest to share/improve that solution? I know there are a lot of different weather station models by Bresser, so maybe there is some work to do but I am willing to share my stuff if anybody is interested…
Dan
Having only remote services for weather data was a pain in my ass so far.
You can use rtl_433 and grab the data from the air if you have an sdr and antenna.
The interesting part where i failed so far is having a cool display for this with breakdowns of temperature curves, splitting the rain total, maybe have a map of your garden & house where the individual sensors are combined, all this could be improved.
I am sure there will be people that would benefit from this, not just me :slight_smile:
GitHub - merbanan/rtl_433: Program to decode radio transmissions from devices on the ISM bands (and other frequencies) put a lot of effort in the moisture sensors from Bresser already :slight_smile:
looks like a cool project! However, it seems to concentrate on using the sensors without a Bresser base station right? So you are completely indpependent and it is up to you how you visualize the data.
My workaround is still dependend on the base station which does the actual decoding of all radio signals. It even adds two more values: temperature + humidity at the location where the base station is installed.
All I do is, taking a short cut, so the base station does send the values to a remote service first but directly to my HA add-on.
The base station has some (okayish) visualization which we use for displaying the temperature across the house and outside. Most of the graphs are limited to 24h (they reset at 0:00) which is often not sufficient. My first approach was to attach a USB pen drive to the base station, which is okay. It stores the values as CSV which can later be processed by some software. However, these data made it nowhere till today - but having them and not needing them is better than the other way around :wink:
When I started with HA I wanted to have the data in my HA database. having a display is nice for seeing the current values but if you want to see statistics, you need more flexibility (at least for me)
Querying the cloud service was okay, but you have to make all your weather data public to stick with the free version. That was my main pain point with the cloud …
TLDR, I still need all the Bresser hardware, but no cloud service anymore, that’s the idea.
There is a project which does what you want:
https://github.com/lhw/cloudweatherproxy
I did not try this yet, since I’m using RTL_433 to get info from the station locally.
i was looking for something similar but did not find it. Okay, so it seems somebody has tried that before :wink:
This approach seems somewhat more complicated:
To use the integration an additional local setup including DNS and a forwarding HTTP server is required, as the destination URLs for the weather station need to be spoofed.
I am not sure why there is a need to spoof anything or setup DNS stuff as long as you have control over your own weather station (can configure where it shall talk to).
However, this might render my approach less useful since I guess a lot of people are already using this integration.
Thank you for that link!
Hi Dan, I am interested whether you still have your setup running? Or did you find a better solution?
sorry for the late response… Currently I am not very active in the HA community.
Yes, I still have my “solution” running. From time to time it gets stuck, so the REST sensors are unavailable. I haven’t figured out why. In such a situation a HA reboot or a plugin restart helps… however, most of the time it does exactly what I want, receiving the data from the Bresser weather station and providing them as sensors.
Hi.
I have the Bresser 7in1 Weatherstation. This one:
Currently I use openhab for most of my smart home, but I am looking to move some things.
My solution for this is running for 4 years without any problems, so I try to remind how it was set up.
I think initially the weather station creates a wifi with a web interface and it was possible for me to enter a custom target for the json data.
With this binding for openhab I create a http listener which receives the json data.
Here is the json parsing: [webhook] New, very simple binding for listening incomming http requests - #9 by Desmond206x - Bindings - openHAB Community
So it works locally and with a easy solution. Maybe this helps us with this topic.
Hi, Dan, i just stumbled over your post, while desperatly searching for a well explained solution to get weatherstation data into homeassistant. I have a bresser wifi clearview 7in1. And also noticed the possibility in its setup to hook it to a 3rd party service. As your solution sounds actually the most simple approach i really want to know how you did exactly. I also found the CloudWeatherProxy custom integration but i have no clue how to setup this CoreDNS, caddy … so hoping for your reply
Hi there,
I just developped the integration you were looking for here:
It’s a plug and play local integration
It works with my Bresser 7-In-1.
