Brightness in awtrix Ulanzi
I just reinstalled my awtrix/Ulanzi clock after some trouble with it.
It seems to be working fine now.
I have read a lot of topics and viewed a lot of videos, but what i don’t understand is: how can I adjust the brightness of the display? Which command do I need?
In the MQTT-configuration I am testing with this:
    "text": "Hallo",
    "ABRI":false,
    "brightness":10,
    "color":"#FF00FF"
And I see the word Hallo, in a nice purple color.
awtrix(1)
But the brightness doesn’t work. What am I doing wrong?
I hope someone can help me?
Regards, Peter
You have a value of 10, that means that the brightness is only set to 10%, you will need to increase the value to see if it updates properly.
There is no difference in brightness if I set it to 1, or 10 or 99.
The display stays very bright. When I go to the settings in the Ulanzi , to check for auto-brightness, it is is turned off, and it says the brightness is set to 47.
But sending a command to show the text in dimmed mode (i.e. brightness = 10) doesn’t work. There must be something wrong in the code.
Regards, Peter
You may want to look into firmware updates then like say this one and then try linking it to HA via MQTT:
found via
https://www.reddit.com/r/homeassistant/comments/131okf7/ulanzi_tc001/
also
