Brilliant-mqtt: local bridge for Brilliant touchscreen panels — lights, power monitoring, motion, even a voice satellite
If you have Brilliant Smart Home Control in-wall touchscreen panels (the ones from brilliant.tech, you've probably tried pairing them into Home Assistant through HomeKit Controller… and watched entities get stuck in setup_retry, pairings drop after restarts, and most of the panel's capabilities stay invisible.
I got tired of that, so I built a proper bridge. brilliant-mqtt runs a small agent on the panel itself that connects to the panel's own internal message bus — the same one Brilliant's HomeKit bridge uses — and publishes everything to your MQTT broker as native Home Assistant MQTT-Discovery entities. Fully local, no cloud, and it coexists with the panel's built-in Alexa and HomeKit.
What you get
  • Lights & switches — every load wired to a panel, plus Brilliant's BLE-mesh dimmers and smart plugs house-wide, with dimming. Mesh devices are published by a single elected panel (with automatic failover), so you get one clean set of entities instead of duplicates from every panel.
  • Whole-home power monitoring — live per-circuit wattage for every load, including always-on gangs you can't see anywhere else, plus dimmer temperatures and fault sensors.
  • Motion & presence — motion from every mesh dimmer/switch (yes, they have motion sensors — Brilliant never exposed them in their own app!) and from the panel faceplate PIR, plus panel-in-use occupancy.
  • Panel management — 25+ entities per panel: screen on/brightness, screensaver, volumes, mic mute, night mode, child lock, firmware auto-update control, Wi-Fi diagnostics, and one-click agent updates from HA.
  • Voice satellite (opt-in) — turn any panel into a local wake-word voice satellite for HA Assist, using the panel's built-in mic and speaker. Wake word runs on the panel; STT/conversation/TTS run in your own Assist pipeline.
How it works
The agent is ~zero-dependency Python running as a resource-capped systemd service in the panel's persistent storage, so it survives firmware OTA updates. The companion HACS integration handles everything over SSH: guided onboarding, agent install, updates from HA (Update entities), and automatic repair after firmware updates. Root SSH is an official Brilliant feature (a toggle in panel settings) — nothing is jailbroken or modified.
Reliability was the whole point: retained MQTT discovery/state (entities survive HA restarts instantly), auto-reconnect with re-sync, a hot diff-poll, stale-stream watchdog, and a reconnect-storm circuit breaker. New in v0.5.5, a bus-health watchdog reboots a panel if Brilliant's internal message bus ever wedges — a rare failure that only a reboot clears — opt-in per panel and guarded so it can't reboot-loop. My 14-panel install has been running it 24/7 through firmware updates for a month.
Security model in one line: per-panel passwords stored in HA's config store, SSH host-key pinned after first use (verified before the password is ever sent), single auth attempt per connect, everything redacted from diagnostics. Full details in the docs.
Getting started
Requirements: Brilliant panel(s) with Root SSH Login enabled, an MQTT broker connected to HA, HACS.
  1. Add the custom repository in HACS: joyfulhouse/brilliant-mqtt (Integration) — or use the one-click badge in the README.
  2. Add the integration; enter one panel's IP + root password.
  3. The flow installs the agent, and your panel's entities appear. Repeat per panel.
Roadmap-ish
Recent releases added the tier-1 panel controls, Wi-Fi and bus-health watchdogs for flaky panels, and v0.5.0's headline: working mesh-load motion — the firmware's own motion latch turns out to be dead, so the bridge derives motion from the raw sensor score stream (validated against mmwave ground truth at ~85% episode recall with essentially zero false triggers). Ideas and PRs welcome — the docs include a full architecture writeup and the reverse-engineered bus reference.
Support this project
This integration was built almost entirely with AI pair-engineering (Claude), which is genuinely how a one-person project reverse-engineers an undocumented Thrift bus, ships 850+ tests, and supports a fleet — but the token bills are real. If brilliant-mqtt rescues your panels from HomeKit purgatory, a coffee helps keep the releases coming:
Bug reports and questions welcome here or on GitHub Issues. If you have a panel model or third-party device hanging off Brilliant that behaves oddly, I'd especially love the diagnostics — I can only test against my own fleet.
Not affiliated with or endorsed by Brilliant NextGen, Inc. MIT licensed.
Update: drive Home Assistant lights from the wall — fully local, no cloud, no SmartThings
This one took a while to get right. The panels ship with a built-in Philips Hue integration — and it turns out you can point it at a local diyHue bridge backed by Home Assistant. The result: a wall slider on the panel controls any HA-managed bulb (Tuya, WiZ, anything HA can drive) natively, as a first-class light tile. Fully local — no SmartThings, no Brilliant cloud, no HomeKit pairing.
What you get
  • Wall sliders → HA lights. Press or dim a load on the panel and it drives the HA entity (which drives the real bulb). On/off is exact; brightness is approximate.
  • Group tiles. Back an HA light group with a single diyHue light and the panel shows one tile for the whole cluster.
  • Room placement. Assigned lights land in their Brilliant rooms on every panel.
  • Survives firmware OTAs. A small “Hue CA recovery” component re-establishes trust after each update, so it doesn’t silently die on you.
How it works (short version)
The panel is a Hue API v1 polling client. Three “walls” to get through, all handled locally:
  • Discovery — diyHue advertises over mDNS as a Hue bridge.
  • Pairing — a credential is written into the panel’s Hue config on its own internal message bus.
  • TLS — the panel pins a Hue CA bundle, so you append your own CA to it (root, fully reversible) and diyHue serves a matching leaf.
Full writeup + runbook: diyHue bridge guide
Honest caveats
  • This is advanced / operator setup today, not a checkbox — you run a diyHue instance on your network and append a CA to each panel. The guide walks through all of it. I’m actively working on making onboarding much easier (closer to a guided setup flow) so this isn’t so hands-on — more on that soon.
  • HA→panel state is poll-bounded (diyHue’s ~10s state poll plus the panel’s own poll), so a tile can lag a few seconds catching up. The command direction (wall → bulb) is prompt.
  • The Hue integration is home-wide and leader-elected across panels, so the CA goes on all of them — the guide and the recovery component handle that for you.
Tag the HA entities you want on the wall with diyhue: include and they show up:
# HA configuration.yaml
homeassistant:
  customize:
    light.backyard_lamps:
      diyhue: include
If you’ve wanted your Brilliant wall sliders to control non-Brilliant bulbs without the cloud, this is the path. Feedback welcome.
So this was working amazing until today, 3 of my 4 panels are fine. the 4th had an ip change AND a SSH password change. This can not be repaired (bug). I deleted the device from HA and then tried to re-add it. Error some packages exist(older version was installed, newer version is trying to be installed also BUG). So I deleted the service from the panel and removed the brilliant-mqtt directory rebooted and tried again. Current panel state could not be captured safely..
Any help would be a appreciated
