Hey !
Ever wanted to add bing / windows lockscreen wallpapers to home assistant ?
Use them as a background somewhere, or in a slideshow ?
It is now possible with the custom integration I made ! It provides an image entity you can use basically everywhere and a text entity with the description ! You can set your language among other things (refresh rate etc.)
More information about what you can do in the repository available here :
It is now available in HACS without adding the repository manually
example use (my TV screensaver handle by HA):
