Hmm, not sure what the issue is. Can you try mounting an folder within users home path?
You could also try replacing image tag latest
with 1.0.0
with 1.0.0
I tried changing the tag to 1.0.0, which didnāt help.
I donāt understand what you mean, isnāt the /usr/src/config/
folder of the container already mapped to the hosts system with the -v (volumes) tag?
Also tried to put the command in a docker-compose which didnāt help. I wanted to check inside the container but when it finished it automatically exits. So I cant go inside the container or copy files if it should have created one.
And is the way I created my client secret alright? Or maybe I made a mistake there? This is the structure I have:
Your client_secret.json
content looks correct!
What I meant is that you should try mounting another folder (from your host) that is owned by the user you are logged in with in your OS, /opt
is owned by the root
user. I suspect we are dealing with write/permission issues from docker container to the host folder /opt/google-assistant-broadcast/config
Here is a example for default user (ubuntu
) in Ubuntu OS, Also, IĀ“m here demonstrating how to start the docker container in interactive mode
so the container does not quit after tokens.json
is generated. This can help you check if the tokens.json
gets created in the folder /usr/src/config
inside the container, when the authentication flow ends.
ubuntu
ownsdocker run --rm -it \
-p 3005:3005 \
-v /home/ubuntu/google-assistant-oauth/config:/usr/src/config \
ismarslomic/google-assistant-oauth:latest \
/bin/ash
node index.js
Do the authentication flow
When the authentication flow is done, verify that tokens.json
is created in container:
ls -al /usr/src/config
exit
tokens.json
exists at hostls -al /home/ubuntu/google-assistant-oauth/config
Yes apparently it were some weird permission issues.
Which is very weird because initially I executed everything with the root user which should have all the permission.
But when I executed it with the pi user (one of my users) it worked after is put sudo before each command. Thanks for your help, much appreciated!
After I got the tokens.json I was able to spin up the broadcast container. Now I have the same problem as @joolui, I always get an empty response back and no sound comes out my Nest speakers.
But this may be a problem with the new google account I created for this use case. It has all the rights like my main google account but it doesnt work yet. Iāll give it some time and otherwise Iāll try it with my main account. But thanks for all the troubleshooting!
Glad you fixed the issue with tokens.json file. I will update the README file to get attention for new users on this topic.
Since Iām not able to reproduce the error you and @joolui is facing, I donāt know how to help. But please let me know if you find out, so I can either make a bugfix or update docs.
I have used the same token for several weeks, without needing to recreate it.
Iāll keep you posted if I find out why it doesnāt broadcast the messages.
What I do find very strange if I look in the Google Console Platform I see there are a few Google Assistant API request, so they go through the API but it doesnāt get played:
In your setup did you have to do specific settings to tell which speakers it could broadcast to?
(I have Google Nest speakers which I can broadcast to with Google Assistant via my phone/car)
Last question, in your OAuth consent screen did you publish the APP? I did not and have it set tot external user type with myself (main google account email address) as a test user).
Can you please register new issue in Github repo, regarding questions in last post? I can provide some input on what you could try to fix the problem.
Hey @ismarslomic. Thanks for getting this back up and running. Iām struggling with getting the tokens. My HASS is hosted in a docker container on a headless server. I donāt have a GUI, let alone a web browser, to paste the link into for the oauth credentials. When I try to use a different system with a gui (on the same network) it obviously borks at the ālocalhost:3005ā portion of the callback. I also tried changing ālocalhostā to the serverās IP, but that also didnāt work.
Any idea how else i can get the token?
To obtain the access token you can start the google-assistant-oauth
container on whatever machine you have access to (server, PC, Mac, etc.). This is a one time job you do to obtain the tokens file, which you need in the google-assistant-broadcast
container.
If you start the google-assistant-oauth
container on your headless server, copy the url to your web browser (you must be on the same network or use VPN), you can replace the localhost
with the IP address of your headless server when the OAuth flow is finished and your browser is redirected.
Hope this helps!
Unfortunately, when I do that I get the following error:
Authorization Error
Error 400: invalid_request
device_id and device_name are required for private IP: http://10.10.1.100:3005/oauth2callback
Learn more
Google oath doesnāt support private ipās so you at minimum need to do the token generation from the machine running the container
I was able to install Firefox into a container and generate the file. However, now Iām getting an āunauthenticatedā issue. Hereās my output:
[2022-06-13T23:06:01.833Z] Sending message (en-GB): Broadcast Hello world!!
[2022-06-13T23:06:02.070Z] [ERROR] Error while broadcasting: Error: 16 UNAUTHENTICATED: Failed to retrieve auth metadata with error: invalid_grant
at Object.callErrorFromStatus (/usr/src/app/node_modules/@grpc/grpc-js/build/src/call.js:31:26)
at Object.onReceiveStatus (/usr/src/app/node_modules/@grpc/grpc-js/build/src/client.js:391:49)
at Object.onReceiveStatus (/usr/src/app/node_modules/@grpc/grpc-js/build/src/client-interceptors.js:328:181)
at /usr/src/app/node_modules/@grpc/grpc-js/build/src/call-stream.js:187:78
at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
code: 16,
details: 'Failed to retrieve auth metadata with error: invalid_grant',
metadata: Metadata { internalRepr: Map(0) {}, options: {} }
[2022-06-13T23:06:02.072Z] [OK] Conversation Completed
[2022-06-13T23:07:28.673Z] Sending message (en-GB): Broadcast Hello world!!
[2022-06-13T23:07:28.904Z] [ERROR] Error while broadcasting: Error: 16 UNAUTHENTICATED: Failed to retrieve auth metadata with error: invalid_grant
code: 16,
This doesnāt seem to be the language issue that you referred to previously; any thoughts on what this one is?
āEdit-- This is your cue to recreate the credentials and try again.
Thanks for your work developing this. Itās working great now!
Still not possible to only play on a specific speaker?
Not as far as I know
Anyone managed to get this to work now that OOB is deprecated?
You canāt really broadcast to a specific device with the way you have it setup because broadcast: ātrueā is sent to Google Assistant. When you do that GA interprets the entire message as broadcast text. If you allowed us to send a command then we could do ābroadcast to {{ a_room_defined_in_google_home }} {{ message }}ā which would be interpreted as a command and then the device/room would be parsed from the beginning of the message and the rest would be sent as a broadcast to an individual or group of devices.
I made this comment on an issue in github. Hopefully you see it and reconsider.
Also, what are the chances you will create this as an addon so itās easier to get installed?
Release v1.0.7 supports sending commands and broadcast to specific speakers. Please give it a try and see if it works out for you.
I dont have any concrete plans moving this to a custom component nor hass addon. I agree there is some treshold to get it up and running, but if you are techy its quite easy. It also depends on a javascript library for Google Assistant SDK, and that doesnt fit directly into an python environment.
But if someone has time to support on creating custom component, that would be very nice! I could also find time to support it!
I see the update and I appreciate the change. I also noticed that quite a few others that were watching github have already tested the change. Thatās great.
Hopefully somebody can pickup the banner and create an addon. For those of us running HA OS that are techy but really hands off it would be a great addition. There was an addon version of assistant relay. Maybe that author (@Apipa169) would be interested in creating an addon for this.
Iāve been looking for a way to send command via home-assistant to google assistant as there is no way to integrate a light/fan I have into home assistant. Playing playing with this and Iām running into an issue sending the message.
Iāve set up and retrieved the docker container for Oauth.
The google-broadast container is running with the environment variable APPEND_BROADCAST_TO_MESSAGE=false
When I try to send a command via curl nothing happens. When looking at the broadcast logs I see the following:
~$ curl -X POST http://localhost:8085/broadcast -d '{"message":"turn on hot water heater"}' -H "Content-Type: application/json"
^C
~$ docker logs 2294bb79ebdd
Paste your code: [2022-12-30T16:20:52.654Z] Sending message (en-GB): turn on hot water heater
[2022-12-30T16:20:52.702Z] Opening OAuth URL. Return here with your code.
Not to sure why it doesnāt proceed from here, iām not convinced I have the oath correct either, as when i run that container, each time it asks me to go to the URL, and accept that i trust my app so i click continue, then have to return to console
EDIT:
Issue was on my end, I ran the container passing the wrong volume in. Recreated and itās working now.
Love this project, thank you so much.
