Broadlink base64 codes size limit?
Is there a maximum size for the base64 code you can send to a Broadlink device? For example, I have a Broadlink RM4 Pro. If I use the example given at Broadlink - Home Assistant, it works just fine.
# Example configuration.yaml entry
script:
  turn_on_tv:
    sequence:
      - service: remote.send_command
          entity_id: remote.bedroom
          command: b64:JgAcAB0dHB44HhweGx4cHR06HB0cHhwdHB8bHhwADQUAAAAAAAAAAAAAAAA=
But if change it to a longer code (this code is for a Luminera LED candle) it fails to send. There are no error messages that I can see.
script:
  turn_on_tv:
    sequence:
          command:   b64:AAAAbQAiAAIBVwCsABYAFgAWABYAFgAWABYAFgAWABYAFgAWABYAFgAWABYAFgA/ABYAPwAWAD8AFgA/ABYAPwAWAD8AFgA/ABYAPwAWAD8AFgAWABYAPwAWABYAFgA/ABYAFgAWABYAFgAWABYAFgAWAD8AFgAWABYAPwAWABYAFgA/ABYAPwAWAD8AFgXkAVcAVQAWDlQ=
