Broadlink switch module reported error below
It happens on Broadlink 0.3 and 0.5 as well
Anybody see this problem?
2017-08-31 14:43:57 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
return fut.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/broadlink.py", line 142, in setup_platform
broadlink_device.auth()
File "/root/.homeassistant/deps/lib/python3.4/site-packages/broadlink/__init__.py", line 203, in auth
response = self.send_packet(0x65, payload)
File "/root/.homeassistant/deps/lib/python3.4/site-packages/broadlink/__init__.py", line 258, in send_packet
payload = self.encrypt(payload)
File "/root/.homeassistant/deps/lib/python3.4/site-packages/broadlink/__init__.py", line 162, in encrypt_pyaes
return "".join([aes.encrypt(bytes(payload[i:i+16])) for i in range(0, len(payload), 16)])
TypeError: sequence item 0: expected str instance, bytes found
I install pyaes but if not install pyaes then has this problem
Anything missing?
2017-08-31 15:17:56 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
File "/root/.homeassistant/deps/lib/python3.4/site-packages/broadlink/__init__.py", line 5, in <module>
from Crypto.Cipher import AES
ImportError: cannot import name 'AES'
return fut.result()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/broadlink.py", line 61, in setup_platform
import broadlink
File "/root/.homeassistant/deps/lib/python3.4/site-packages/broadlink/__init__.py", line 7, in <module>
import pyaes
ImportError: No module named 'pyaes'
