Hi all,
I’m using the Home Assistant Broadlink integration, and it works fine for configuring a Sony TV remote, and a remote that controls LED candles.
But I also have a ceiling fan that uses a remote and Home Assistant won’t register the remote presses when I put it into learning mode (the Broadlink app works ok and it detects the remote signals fine).
The remote is RF and running on a 433.77MHz frequency.
I tried both the Broadlink Manager Windows application, and the docker version, to see if I could capture the codes manually, but neither of them work with my RM4 Pro S, see thread: Broadlink Manager Windows see invalid device, docker version sees nothing? · Issue #47 · t0mer/broadlinkmanager-docker · GitHub
Cheers,
Justin
