According to the documentation HERE for the integration here is an example:
# Example configuration.yaml entry
switch:
- platform: broadlink
mac: MAC_ADDRESS
switches:
- name: Philips TV
command_on: JgAcAB0dHB44HhweGx4cHR06HB0cHhwdHB8bHhwADQUAAAAAAAAAAAAAAAA=
command_off: JgAaABweOR4bHhwdHB4dHRw6HhsdHR0dOTocAA0FAAAAAAAAAAAAAAAAAAA=
Why there is no friendly_name: "Philips TV"
and entity_id: switch.philips_tv
, but instead there is only - name: Philips TV
I am new to this, but I have noticed usually everything in Home Assistant has both “friendly name” and “entity id” but here I cant find the correct code to use it. Only “- name” and why there is - in front?
Thank you and sorry for the basic question.
P.S.
In the example above the “friendly_name” is the same as “-name” and the “entity_id” is created automatically following the naming “switch.philips_tv”. What if I want to be different?
Example:
“friendly_name” Winter time example
“entity_id” switch.summer_time_example
I wanted to change the entity and I get this message:
And link to here - This entity does not have a unique ID? - Home Assistant
