Yup, just upgraded the broadlink climate component and get the same sort of error:
2018-06-18 07:12:42 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform broadlink
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 212, in coro
res = func(*args, **kw)
File "/config/custom_components/climate/broadlink.py", line 92, in async_setup_platform
broadlink_device = broadlink.rm((ip_addr, 80), mac_addr, None)
TypeError: __init__() takes 3 positional arguments but 4 were given
return fut.result()
2018-06-18 07:12:43 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform broadlink
return fut.result()
2018-06-18 07:12:44 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform broadlink
return fut.result()
2018-06-18 07:12:44 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
return fut.result()
Does anyone have a fix? Am on Home Assistant 70.1 running as a Docker container btw!
Update: Going back to the broadlink.py from 3 months ago solved this issue!
