Broadlink IR code for Motorola VIP2262 ou VIP2502
Hi everybody, I’m trying to make my broadlink mini 3 working with my set top box Motorola VIP2502.
Many other things work but that set top box have weird code… I tryed to learn the raw code from the remote without succes. Every time I try, it’s a different code so I found a dabatase on internet but I’m not sure to understand… It seem there have 2 HEX codes for a button and a kind of instruction (maybe it’s a frequency or something like that…
Ex for CHANNEL DOWN I have
Code 1
sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,10,6,16,6,3243
Hexcode 1
0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 0010 0006 0CAB
Code 2
sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,10,6,16,6,3231
Hexcode 2
0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 0010 0006 0C9F
If someone can explain how that work and how to convert that in raw code, I’ll really appreciate.
Thanks!
my 5 cents
broadlink saved it code a base64
have you tryed convert the hex to base64
so
went to here
https://base64.guru/converter/encode/hex
found out what the base64 are for each hexcode1 hexcode2
so join it all together
build a switch
switch:
  - platform: broadlink
    host: bla.bla.bla
    mac: 'bla.bla.bla'
    timeout: 15
    switches:
      ir_code:
        friendly_name: "ir code"
        command_on: 'AAAAcwAAABIADwAKAAYACgAGABYABgAQAAYAEAAGAAoABgAKAAYACgAGAAoABgAKAAYAFgAGABAABgAWAAYACgAGABYABgAKAAYAEAAGDKs='
        command_off: 'AAAAcwAAABIADwAKAAYACgAGABYABgAQAAYAEAAGAAoABgAKAAYACgAGAAoABgAWAAYAFgAGABAABgAWAAYACgAGABYABgAKAAYAEAAGDJ8='
and the command_on is the hexcode1 to base64
and the command_on is the hexcode2 to base64
do config check then restart and pray and test
good luck
I think that my set top box is a VIP2502, but the brand seems to be Arris, not Motorola.
Anyway, unfortunately I could not make it work with a Broadlink Mini 3. The Mini seems to learn the codes from the remote but it never worked. Changed it to a Logitech Harmony Hub and works fine from minute zero. It seems there is something that the Broadlink Mini cannot do. Sorry for the bad news…
Yes Arris and Motorola Vip2502 is the same…
On the Broadlink app, i found a remote working so its possible to control that set top box using broadlink mini.
I only need to know the good code…
I also contacted broadlink to ask them to give me that code but… Dont ask to much to Chineese company :wink:
I’ll try this but i would like to understand what is the first part or each hexcode, the code 1 and code 2. That could help me…
I don’t know if there is a way to extract the codes from Logitech Hub. If there is a way perhaps I could do it and send them to you…
Regards.
Thanks a lot, I continu to read and test with the HEX codes I found on internet but if I didnt find, I’ll look if your proposition is possible. I found on github forum someone how look for the same set top box than me…
I finaly can confirm the codes for a VIP2262 or 2502. The IR code I found where the good codes.
I personnaly test all the digit and enter using Home Assistant and Broadlink mini 3.
Here’s the code (both code for each function is working you can chose 1 or 2) I kept all the codes info if that can help someone
function CHANNEL DOWN
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,10,6,16,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 0010 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFFAUJBQ4FAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,10,6,16,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 0010 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFFAUJBQ4FAAt/DQU=
function CHANNEL UP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,10,6,10,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 000A 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFFAUJBQkFAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,10,6,10,6,323
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 000A 0006 000A 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFFAUJBQkFAAuEDQU=
function CLEAR
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,22,6,16,6,28,6,22,6,3212
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0016 0006 0010 0006 001C 0006 0016 0006 0C8C
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRQFDgUZBRQFAAtuDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,22,6,16,6,28,6,22,6,3200
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0016 0006 0010 0006 001C 0006 0016 0006 0C80
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRQFDgUZBRQFAAtjDQU=
function CURSOR DOWN
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,22,6,16,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 0010 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUUBQ4FAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,22,6,16,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 0010 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUUBQ4FAAt0DQU=
function CURSOR ENTER
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,28,6,10,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 001C 0006 000A 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUZBQkFAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,28,6,10,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 001C 0006 000A 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUZBQkFAAt0DQU=
function CURSOR LEFT
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,22,6,22,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 0016 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUUBRQFAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,22,6,22,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 0016 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUUBRQFAAtuDQU=
function CURSOR RIGHT
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,22,6,28,6,3219
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 001C 0006 0C93
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUUBRkFAAt0DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,22,6,28,6,3206
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 001C 0006 0C86
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUUBRkFAAtoDQU=
function CURSOR UP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,22,6,10,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 000A 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUUBQkFAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,22,6,10,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0016 0006 000A 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUUBQkFAAt5DQU=
function DIGIT 0
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,10,6,10,6,3261
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 000A 0006 0CBD
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUJBQkFAAuaDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,10,6,10,6,3249
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 000A 0006 0CB1
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUJBQkFAAuPDQU=
function DIGIT 1
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,10,6,16,6,3255
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 0010 0006 0CB7
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUJBQ4FAAuVDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,10,6,16,6,3243
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 0010 0006 0CAB
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUJBQ4FAAuKDQU=
function DIGIT 2
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,10,6,22,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 0016 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUJBRQFAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,10,6,22,6,3237
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 0016 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUJBRQFAAuEDQU=
function DIGIT 3
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,10,6,28,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 001C 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUJBRkFAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,10,6,28,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 000A 0006 001C 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUJBRkFAAt/DQU=
function DIGIT 4
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,16,6,10,6,3255
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 000A 0006 0CB7
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUOBQkFAAuVDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,16,6,10,6,3243
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 000A 0006 0CAB
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUOBQkFAAuKDQU=
function DIGIT 5
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,16,6,16,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 0010 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUOBQ4FAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,16,6,16,6,3237
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 0010 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUOBQ4FAAuEDQU=
function DIGIT 6
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,16,6,22,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 0016 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUOBRQFAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,16,6,22,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 0016 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUOBRQFAAt/DQU=
function DIGIT 7
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,16,6,28,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 001C 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUOBRkFAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,16,6,28,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0010 0006 001C 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUOBRkFAAt5DQU=
function DIGIT 8
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,22,6,10,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 000A 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUUBQkFAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,22,6,10,6,3237
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 000A 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUUBQkFAAuEDQU=
function DIGIT 9
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,22,6,16,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 0010 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUUBQ4FAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,22,6,16,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 0010 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUUBQ4FAAt/DQU=
function ENTER
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,28,6,22,6,10,6,16,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 001C 0006 0016 0006 000A 0006 0010 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRkFFAUJBQ4FAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,28,6,22,6,10,6,16,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 001C 0006 0016 0006 000A 0006 0010 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRkFFAUJBQ4FAAtuDQU=
function EXIT
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,16,6,16,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0010 0006 0010 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUOBQ4FAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,16,6,16,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0010 0006 0010 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUOBQ4FAAt5DQU=
function FAVORITE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,28,6,22,6,16,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0016 0006 0010 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFGQUUBQ4FAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,28,6,22,6,16,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0016 0006 0010 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFGQUUBQ4FAAtuDQU=
function FORWARD
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,22,6,10,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 0016 0006 000A 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFFAUUBQkFAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,22,6,10,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 0016 0006 000A 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFFAUUBQkFAAt5DQU=
function GUIDE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,28,6,10,6,28,6,10,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 001C 0006 000A 0006 001C 0006 000A 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRkFCQUZBQkFAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,28,6,10,6,28,6,10,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 001C 0006 000A 0006 001C 0006 000A 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRkFCQUZBQkFAAtuDQU=
function INFO
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,28,6,28,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 001C 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUZBRkFAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,28,6,28,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 001C 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUZBRkFAAtuDQU=
function INTERACTIVE TV
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,28,6,28,6,28,6,16,6,3200
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 001C 0006 001C 0006 001C 0006 0010 0006 0C80
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRkFGQUZBQ4FAAtjDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,28,6,28,6,28,6,16,6,3188
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 001C 0006 001C 0006 001C 0006 0010 0006 0C74
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRkFGQUZBQ4FAAtYDQU=
function MENU DVR
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,10,6,16,6,10,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 0010 0006 000A 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FCQUOBQkFAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,10,6,16,6,10,6,3237
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 0010 0006 000A 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FCQUOBQkFAAuEDQU=
function MENU MAIN
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,16,6,16,6,10,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0010 0006 000A 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FDgUOBQkFAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,16,6,16,6,10,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 0010 0006 0010 0006 000A 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FDgUOBQkFAAt/DQU=
function MENU SETUP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,28,6,22,6,10,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0016 0006 000A 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFGQUUBQkFAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,28,6,22,6,10,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0016 0006 000A 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFGQUUBQkFAAt0DQU=
function MUTE TOGGLE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,28,6,16,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 0010 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUZBQ4FAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,28,6,16,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 0010 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUZBQ4FAAt5DQU=
function PAUSE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,28,6,10,6,10,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 000A 0006 000A 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFGQUJBQkFAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,28,6,10,6,10,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 000A 0006 000A 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFGQUJBQkFAAt/DQU
function PLAY
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,28,6,10,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 001C 0006 000A 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFFAUZBQkFAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,28,6,10,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 001C 0006 000A 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFFAUZBQkFAAt0DQU=
function POWER TOGGLE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,28,6,10,6,3243
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 000A 0006 0CAB
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUZBQkFAAuKDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,28,6,10,6,3231
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 001C 0006 000A 0006 0C9F
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUZBQkFAAt/DQU=
function PREVIOUS CHANNEL
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,10,6,22,6,22,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 0016 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFCQUUBRQFAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,10,6,22,6,22,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 000A 0006 0016 0006 0016 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFCQUUBRQFAAt5DQU=
function RECORD
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,28,6,16,6,28,6,3219
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0010 0006 001C 0006 0C93
Broadlink 1
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,28,6,16,6,28,6,3206
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 0010 0006 001C 0006 0C86
Broadlink 2
function REPLAY
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,10,6,28,6,16,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 001C 0006 0010 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFGQUOBRkFAAt0DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,10,6,28,6,16,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 001C 0006 0010 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FCQUZBQ4FAAt0DQU=
function RETURN
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,22,6,10,6,10,6,28,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0016 0006 000A 0006 000A 0006 001C 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRQFCQUJBRkFAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,22,6,10,6,10,6,28,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0016 0006 000A 0006 000A 0006 001C 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRQFCQUJBRkFAAt0DQU=
function REVERSE
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,22,6,22,6,16,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 0016 0006 0010 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFFAUUBQ4FAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,22,6,22,6,16,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0016 0006 0016 0006 0010 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFFAUUBQ4FAAt0DQU=
function SEARCH
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,22,6,10,6,16,6,22,6,3231
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0016 0006 000A 0006 0010 0006 0016 0006 0C9F
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRQFCQUOBRQFAAt/DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,22,6,10,6,16,6,22,6,3219
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0016 0006 000A 0006 0010 0006 0016 0006 0C93
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRQFCQUOBRQFAAt0DQU=
function SKIP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,16,6,10,6,28,6,10,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 001C 0006 000A 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQ4FCQUZBQkFAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,16,6,10,6,28,6,10,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 0010 0006 000A 0006 001C 0006 000A 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQ4FCQUZBQkFAAt5DQU=
function STOP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,28,6,10,6,16,6,3237
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 000A 0006 0010 0006 0CA5
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFGQUJBQ4FAAuEDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,28,6,10,6,16,6,3225
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 001C 0006 000A 0006 0010 0006 0C99
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFGQUJBQ4FAAt5DQU=
function TV/VIDEO
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,28,6,22,6,22,6,10,6,3219
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 001C 0006 0016 0006 0016 0006 000A 0006 0C93
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRkFFAUUBQkFAAt0DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,28,6,22,6,22,6,10,6,3206
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 001C 0006 0016 0006 0016 0006 000A 0006 0C86
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRkFFAUUBQkFAAtoDQU=
function VIDEO ON DEMAND
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,28,6,28,6,10,6,10,6,3225
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 001C 0006 001C 0006 000A 0006 000A 0006 0C99
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBRkFGQUJBQkFAAt5DQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,28,6,28,6,10,6,10,6,3212
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 001C 0006 001C 0006 000A 0006 000A 0006 0C8C
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBRkFGQUJBQkFAAtuDQU=
function VOLUME DOWN
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,16,6,10,6,16,6,3249
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0010 0006 000A 0006 0010 0006 0CB1
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFDgUJBQ4FAAuPDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,16,6,10,6,16,6,3237
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0010 0006 000A 0006 0010 0006 0CA5
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFDgUJBQ4FAAuEDQU=
function VOLUME UP
code1 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,10,6,22,6,16,6,22,6,10,6,16,6,10,6,10,6,3255
hexcode1 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0010 0006 0016 0006 000A 0006 0010 0006 000A 0006 000A 0006 0CB7
Broadlink 1 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUJBRQFDgUUBQkFDgUJBQkFAAuVDQU=
code2 sendir,1:1,1,36000,1,1,15,10,6,10,6,22,6,16,6,16,6,10,6,10,6,10,6,10,6,22,6,22,6,16,6,22,6,10,6,16,6,10,6,10,6,3243
hexcode2 0000 0073 0000 0012 000F 000A 0006 000A 0006 0016 0006 0010 0006 0010 0006 000A 0006 000A 0006 000A 0006 000A 0006 0016 0006 0016 0006 0010 0006 0016 0006 000A 0006 0010 0006 000A 0006 000A 0006 0CAB
Broadlink 2 JgAmAA0JBQkFFAUOBQ4FCQUJBQkFCQUUBRQFDgUUBQkFDgUJBQkFAAuKDQU=
I use this tool to convert the Pronto Hex to Broadlink Base64 that work great.
Thanks for that tool and see at the end of this post for the complete command code
Thank you, François. Maybe some day I can go back to my RM Mini 3. Great job.
How did you apply these codes?
Create a switch under your broadlink in YAML
Put those Switches on your HA pages…
Hello all, I cant see code for RECORD event. Can you please post it? Thank you!
Any chance you could post the buttons in YAML format?
