Broadlink IR code --> switch
Is it possible to create a “switch” from only a Broadlink IR code?
I want to make an automation such as:
  • Turn on a switch (IR code to set the heat pump to 18 degrees) when device tracker gets signal to group.device_tracker = away
  • Turns off the TV in the living room if group.device_tracker = away
    May also be easier for Google Home to understand … “Hey Goorle, turn on / off …”
The broadlink ir_codes are switches, are they not?
Unless I misunderstand the question. :thinking:
if I’m going to make an automation like this … how should switch.climate_18_low look like?
- alias: Set climate to 18-low if away
    - platform: state
      entity_id: group.family
      state: 'away'
    - service: homeassistant.turn_off
      entity_id: switch.climate_18_low
All I got to work with is a code like this:
JgC8AXI6DRANLA0QDQ8NEA0PDg8NEA0PDg8NEA0PDRANLA0QDQ8NEA0PDg8NEA0PDS0NLA0sDRANDw4sDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANEA0PDRANDw4PDSwNLA4PDRANDw4PDRANAAFVcjoNEA0sDRANDw0QDQ8ODw0QDQ8ODw0QDQ8NEA0sDRANDw0QDQ8ODw0QDQ8NLQ0sDSwNEA0PDiwNDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0sDRANDw0sDg8NEA0PDg8NDw4PDSwODw0QDSwNEA0PDRANDw4PDRANDw0QDQ8OLA0sDSwODw0QDSwNLA4PDQ8ODw0sDRANLA0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDSwOLA0sDRANDw0QDQ8ODw0QDQ8NEA0PDiwNLA0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLQ0PDRANDw0QDQ8ODw0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLA4sDSwNLA4sDQ8NLA4PDQANBQAAAAAAAAAAAAAAAA==
Your ir code goes in your broadlink config…
switch:
  - platform: broadlink
    host: 192.168.x.x
    mac: 'XX:XX:XX:XX:XX'
    switches:
      climate_18_low:
        friendly_name: "Climate 18 Low"
        command_on: 'JgC8AXI6DRANLA0QDQ8NEA0PDg8NEA0PDg8NEA0PDRANLA0QDQ8NEA0PDg8NEA0PDS0NLA0sDRANDw4sDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANEA0PDRANDw4PDSwNLA4PDRANDw4PDRANAAFVcjoNEA0sDRANDw0QDQ8ODw0QDQ8ODw0QDQ8NEA0sDRANDw0QDQ8ODw0QDQ8NLQ0sDSwNEA0PDiwNDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0sDRANDw0sDg8NEA0PDg8NDw4PDSwODw0QDSwNEA0PDRANDw4PDRANDw0QDQ8OLA0sDSwODw0QDSwNLA4PDQ8ODw0sDRANLA0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDSwOLA0sDRANDw0QDQ8ODw0QDQ8NEA0PDiwNLA0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLQ0PDRANDw0QDQ8ODw0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLA4sDSwNLA4sDQ8NLA4PDQANBQAAAAAAAAAAAAAAAA=='
        command_off: 'JgC8AXI6DRANLA0QDQ8NEA0PDg8NEA0PDg8NEA0PDRANLA0QDQ8NEA0PDg8NEA0PDS0NLA0sDRANDw4sDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANEA0PDRANDw4PDSwNLA4PDRANDw4PDRANAAFVcjoNEA0sDRANDw0QDQ8ODw0QDQ8ODw0QDQ8NEA0sDRANDw0QDQ8ODw0QDQ8NLQ0sDSwNEA0PDiwNDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NEA0sDRANDw0sDg8NEA0PDg8NDw4PDSwODw0QDSwNEA0PDRANDw4PDRANDw0QDQ8OLA0sDSwODw0QDSwNLA4PDQ8ODw0sDRANLA0QDQ8ODw0QDQ8NEA0PDg8NEA0PDRANDw4PDSwOLA0sDRANDw0QDQ8ODw0QDQ8NEA0PDiwNLA0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLQ0PDRANDw0QDQ8ODw0sDg8NEA0PDRANDw4PDRANDw0QDQ8ODw0QDQ8NEA0PDg8NLA4sDSwNLA4sDQ8NLA4PDQANBQAAAAAAAAAAAAAAAA=='
Then the automation is exactly what you already have.
Broadlink doc…
Thank you @anon43302295 !
Is it possible to send two codes?
if I want to see the Discovery channel then it is number 32 in the channel list. Is it possible to send code for 3 and 2 in one command?
Not in one command, but in two commands one after the other:
- service: homeassistant.turn_on
  entity_id: switch.tv_remote_3
  entity_id: switch.tv_remote_2
