Now it tells me only Platform media player not found…
I have done the same with Climate and it’s all right
With media player not found instead
Hi, it seems to be fixed 12 hours ago.
yes thanks, installed and running in .84.1
up?
Anyone use power_consumption_threshold?
Yes, it’s not workin in 0.84.1
hi
upgraded to 86.1 now this custom component doesnt work, anybody have any ideas? worked ok in previous version.
thanks
Reboot whole hardware
done that, couple of times.
i get this error in log file if that helps?
File "/config/custom_components/media_player/broadlink.py", line 20, in <module> from homeassistant.helpers.restore_state import async_get_last_state
ImportError: cannot import name 'async_get_last_state' 2019-01-24 20:55:31 ERROR (MainThread)
[homeassistant.loader] Unable to find platform broadlink 2019-01-24 20:55:31 ERROR (MainThread)
[homeassistant.loader] Error loading custom_components.media_player.broadlink. Make sure all dependencies are installed Traceback (most recent call last):
cheers
You need to update the broadlink.py
Stopped working in 0.88.0b0
2019-02-14 09:29:57 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.media_player.broadlink. Make sure all dependencies are installed
File "/srv/ha/lib/python3.6/site-packages/homeassistant/loader.py", line 147, in _load_file
module = importlib.import_module(path)
File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/homeassi/.homeassistant/custom_components/media_player/broadlink.py", line 13, in <module>
from homeassistant.components.media_player import (
ImportError: cannot import name 'SUPPORT_TURN_ON'
2019-02-14 09:29:57 ERROR (MainThread) [homeassistant.loader] Unable to find platform broadlink
Trial and error fix
MediaPlayerDevice, PLATFORM_SCHEMA)
from homeassistant.components.media_player.const import (
SUPPORT_TURN_ON, SUPPORT_TURN_OFF, SUPPORT_VOLUME_MUTE,
SUPPORT_VOLUME_STEP, SUPPORT_SELECT_SOURCE, SUPPORT_PREVIOUS_TRACK,
SUPPORT_NEXT_TRACK)
from homeassistant.const import (
CONF_HOST, CONF_MAC, CONF_TIMEOUT, STATE_OFF, STATE_ON,
STATE_PLAYING, STATE_PAUSED, STATE_UNKNOWN, CONF_NAME, CONF_FILENAME)
Thanks for the hint. The component updated on GitHub.
There is a problem with the new version:
15 2019 10:55:55 GMT+0100 (CET)
Traceback (most recent call last): File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/loader.py”, line 117, in _load_file module = importlib.import_module(path) File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/importlib/init.py”, line 126, in import_module return _bootstrap._gcd_import(name[level:], package, level) File “<frozen importlib._bootstrap>”, line 978, in _gcd_import File “<frozen importlib._bootstrap>”, line 961, in _find_and_load File “<frozen importlib._bootstrap>”, line 950, in _find_and_load_unlocked File “<frozen importlib._bootstrap>”, line 655, in _load_unlocked File “<frozen importlib._bootstrap_external>”, line 678, in exec_module File “<frozen importlib._bootstrap>”, line 205, in _call_with_frames_removed File “…custom_components/media_player/broadlink.py”, line 15, in <module> from homeassistant.components.media_player.const import ( ModuleNotFoundError: No module named ‘homeassistant.components.media_player.const’
Are you in the beta version?
No. 0.87.1
This update works only with the next version of HA.
Right.
Will be good to mention this at Github and keep both versions of the component.
You’re right. I plan to open a beta branch. Sorry for the inconvenience
I hadn’t seen this component. I ended up wroting my own:
It has two nice feature missing here. But might be lacking other.
- support volume control by percentage/slider for media players supporting a ir code for at least one fixed volume (yamahas for example)
- can generate the ir command from an (protocol, device, subdevice, function) tuples from https://irdb.tk. For now it needs manual install of my irgen python package.
Don’t mean to hijack thread.
