Broadlink IR Media Player (For old, dump TVs)
Just updated to 0.88
2019-02-21 10:18:55 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.media_player.broadlink. Make sure all dependencies are installed
File "/usr/local/lib/python3.7/site-packages/homeassistant/loader.py", line 147, in _load_file
module = importlib.import_module(path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/media_player/broadlink.py", line 13, in <module>
from homeassistant.components.media_player import (
ImportError: cannot import name 'SUPPORT_TURN_ON' from 'homeassistant.components.media_player' (/usr/local/lib/python3.7/site-packages/homeassistant/components/media_player/__init__.py)
2019-02-21 10:18:55 ERROR (MainThread) [homeassistant.loader] Unable to find platform broadlink
Scroll 8 posts up!
YOu mean replace with the code you provided the below code?
    SUPPORT_TURN_ON, SUPPORT_TURN_OFF, SUPPORT_VOLUME_MUTE,
    SUPPORT_VOLUME_STEP, SUPPORT_SELECT_SOURCE, SUPPORT_PREVIOUS_TRACK,
    SUPPORT_NEXT_TRACK, MediaPlayerDevice, PLATFORM_SCHEMA)
from homeassistant.const import (
    CONF_HOST, CONF_MAC, CONF_TIMEOUT, STATE_OFF, STATE_ON,
    STATE_PLAYING, STATE_PAUSED, STATE_UNKNOWN, CONF_NAME, CONF_FILENAME)
from homeassistant.helpers.event import (async_track_state_change)
from homeassistant.helpers.restore_state import RestoreEntity
from homeassistant.core import callback
from configparser import ConfigParser
from base64 import b64encode, b64decode
No, i mean update from GitHub.
I think that [custom_components.json] have to be updated from
“local_location”: “custom_components/media_player/broadlink.py”
to
“local_location”: “custom_components/broadlink/media_player.py”
@Vassilis, component will not be found by HA in 0.91.0b2.
Looks like it needs another name?
Ha! That was easy, just renamed
.homeassistant/custom_components/broadlink
to
.homeassistant/custom_components/broadlink1
and also the media_players
media_player:
  - platform: broadlink1
Lesson learned!
New version - 0.92 and component not loaded.
anyone who still got this working
please guide,
thanks
Create the folder and rename like in my post above.
Create an __init__.py file with DOMAIN = "broadlink1" in it.
Dear,
Will this work on 0.92
I’m on 0.92.0 and it works.
(ha) homeassi:~$ ls -l .homeassistant/custom_components/broadlink1/
insgesamt 20
-rw-rw-r-- 1 homeassi homeassi    22 Apr 18 09:18 __init__.py
-rw-rw-r-- 1 homeassi homeassi 10395 Feb 15 11:14 media_player.py
Can please provide me ur custom component files,
Thanks in adv
The media_player.py is the original from github just renamed from broadlink.py
The __init__.py
(ha) homeassi:~/.homeassistant/custom_components/broadlink1$ cat __init__.py
Like said 3 posts above.
Why not use SmartIR? This component is outdated. If you need help to convert your INI files, please PM me.
Ah thanks a lot, using SmartIR was too much on my plate as I jump from 0.87 to 0.91, and this just makes an easy workaround for a while !
EDIT : @Vassilis, I wrote that just before your comment. You’re right, I’m planning to move to SmartIR, but later as I still have a lot to debug !
Thanks for the hint!
Dear, i tried this
i was using broadlink switch as template in binary sensor to detect my switch as on/off and control it,
can you please guide me how to set this config with new available command
Blockquote
  • platform: template
    switches:
    samsungtvpower:
    friendly_name: Samsung Hall
    value_template: “{{ states.input_boolean.samsungtv_power_status.state == ‘on’ }}”
    turn_on:
    - service: switch.broadlink_send_packet_192_168_1_25
    packet:
    - “JgBGAJKVETkRORA6ERQRFBEUERQRFBE5ETkQOhAVEBUQFREUEBUQOhEUERQRORE5EBURFBA6EBUQOhE5EBUQFRA6EDoRFBEADQUAAA==”
    entity_id: input_boolean.samsungtv_power_status
    turn_off:
    packet:
    - “JgBGAJOVEDoQOhA6DxYPFhAVEBUQFRA6ETkROREUERQRFBEUEBUQFREUERQRORE5EBUQFRE5ETkRORE5ERUQFRA6DzsPFhAADQUAAA==”
    - service: input_boolean.turn_off
    icon_template: mdi:television-classic
i make it worked
i need to add switch.py form original home-assistant component broadlink
to my custom_components/broadlink1/
and i need to change my broadlink switch platform to broadlink1 in my binary sensor.
thanks for guiding
Dear,
if someone can guide me
i would like to link my media_player.onkyo (which works with broadlink component) to turn on/off with my switch.onkyo component and should reflect its status accordingly.
i have onkyo receriver which is non-network device.
Please guide me how can i do this.
thanks
