Hi all,
I have a RM4 that work well with the broadlink integration.
I have a clim with a remote.
This remote have one button to power ON and OFF
This remote have one button to set power to level LOW or level HIGH
So, on the original ir remote, the power ON & OFF is the same IR code, like the power button ( first press is low, second press for HIGH
When i call the service to power on or set power to LOW all is working fine.
But when i call again the script to POWER OFF or set level to HIGH, nothing happen ( even if i see the RM4 sending the IR command )
Does anyone have an idea ? Thanks !
Here are my two script :
ir_clim_power:
sequence:
- service: remote.send_command
entity_id: remote.rm4_mini_remote
device: clim
command: power
ir_clim_chauffage:
sequence:
device: clim
command: chauffage
