I asked ChatGPT why the recordings differ:
Why do the recordings differ?
The differences in your recorded IR (infrared) codes despite identical functionality are due to how IR remotes often encode their signals—and how recording tools interpret them.
Key reasons for variation:
1.
Tolerance in Timing
IR remotes send data as a series of modulated pulses (usually 38 kHz) with precise timing. Consumer-grade IR recorders don’t always capture this timing with millisecond-level precision, so small variations in pulse durations or intervals result in different encoded base64 data—even when the signal is functionally identical.
2.
Protocol Permissiveness
Many IR protocols (e.g., NEC, Sony, RC5, proprietary formats) allow for:
- Tolerances in pulse length
- Repeat codes or variations on retransmission
- Checksum or toggle bits that change with each press
So your remote might:
- Change a sequence counter
- Flip a toggle bit
- Vary gap timing slightly
These still get accepted by the amp because the command payload is the same or functionally equivalent.
3.
Encoding Artifacts
Your signal is encoded as base64, almost certainly representing raw pulse duration values (often in LIRC’s Pronto or Broadlink-like format). Any small difference in pulse width will yield a different binary pattern, hence different base64 strings.
4.
Multiple Command Variants
Some remotes intentionally rotate among a few valid encodings for a single command. This adds resilience to noise or supports auto-repeat detection.
Conclusion
Even though the encoded IR data looks different, the decoded payloads are functionally equivalent, and the amp’s IR decoder is designed to tolerate minor variation or interpret multiple forms of the same command.
If you’re trying to automate IR transmission (e.g., via ESPHome, LIRC, or Broadlink), just use one of the working variants. Most systems don’t need you to alternate or cycle variants unless the device specifically requires it.
I also asked for a detailed analysis of the data itself:
Detailed analysis of base64 IR data for Cronus Magnum III Mute Button
The data you’ve shown are base64-encoded representations of raw IR signals, likely in a format similar to that used by Broadlink, LIRC, or Pronto Hex systems. Let’s decode and analyze one signal fully, and then generalize to explain why they differ.
Step 1: Decode Base64
Taking the first string from “mute2”:
"JgAYABodOjo5HhweGx8cHR0dHTodHTk7GwANBQ=="
Base64 decoding (in hex):
26 00 18 00 1A 1D 3A 3A 39 1E 1C 1E 1C 1B 1F 1C 1D 1D 1D 3A 1D 1D 39 3B 1B 00 0D 05
Breaking this down:
Byte(s) |
Meaning (assumed) |
0x26 |
Likely a header (Jg== = 0x26) — denotes IR protocol or mode |
0x00 0x18 |
Number of bursts or encoding type (varies by format) |
Remaining |
Raw pulse data — alternating on and off durations |
Let’s convert them to decimal pulse widths:
[26, 0, 24, 26, 29, 58, 58, 57, 30, 28, 30, 28, 27, 31, 28, 29, 29, 29, 58, 29, 29, 57, 59, 27, 0, 13, 5]
These represent durations in ticks, often in units of us × scaling factor. In many IR formats, each value represents the length of an on or off period in microseconds divided by a constant (commonly 26.3μs in Pronto Hex, or just “tick units” in LIRC or Broadlink).
So, alternating:
- Index 0: ON for 26 ticks
- Index 1: OFF for 0 (likely noise or sync)
- Index 2: ON for 24
- Index 3: OFF for 26
- Index 24: OFF for 5 ticks
Together, this is a full signal made up of:
[ON, OFF, ON, OFF, ..., ON, OFF]
Step 2: Why It Differs Yet Works
The structure encodes the same logical command , but:
- Slight timing jitter (from repeat presses or electrical noise) causes minor shifts in the durations.
- Some remotes alternate toggle bits (e.g., Sony and NEC do this).
- Broadlink (and others) often do no normalization, so each raw IR capture has timing jitter.
- Differences of ±1 tick (~±26μs) are usually below the detection threshold for the receiver.
Step 3: Verifying Equivalence
Even though the signals differ:
- They match the same burst pattern: same number of pulses, similar timings
- The core modulated pattern maps to the same command bitstream
- The amplifier accepts any of them because its IR decoder uses a tolerant windowing algorithm
If we were to decode them all to binary bits (which requires knowing the protocol—e.g., NEC, RC5, etc.), you’d likely get the same command ID, e.g., 0xA45B or similar.
Summary
- These base64 strings encode raw IR pulse durations
- Timing varies slightly per press due to normal hardware behavior
- Functionally, they are equivalent at the decoder’s logic level
- You only need to store one working code for automation
If desired, I can extract and plot the waveform to show equivalence, or try decoding to a bit-level signal assuming a specific protocol (e.g., NEC or Sony).
