Broadlink...IS my packet too short? Size matters!
Hi! I have been using Broadlink RM Mini successfully for quite some time. I set up my commands by learning my IR remote buttons via the switch.broadlink_learn_command_X_X_X service, and it worked well!
Since then, HA has been updated, I’ve transitioned to Hass.io, and lots has changed in my setup - so I wanted to add some new remotes.
I’m going through the steps fine to learn_command, and despite the component being a bit buggy, I’m getting a packet to send as a persistent notification.
For some reason, the codes I’m getting are way too short - compared to what I got back when I first set up my system (back on Hassbian).
Here’s an example…
Previous packet:
JgDOAJGWFBETEhM3EzYTEhM3ExITEhITEhITNxM3EhMSNxMSExITEhM2EzcTEhM3EzYUEhI3EzcSEhMSEzcTExETEjcTExIABgWRlhQ2EwAMWZKWETkRAAxbkZYTNxMADFmSlhA6EQAMW5GWEzcSAAxak5UROREADFqVkxI4EwAMWZGWEzcTAAxZkpYUNhMADFmRlhM3EwAMWZKWFDYTAAxZlJMTNxQADFiSlhM3EgAMWZKWEzcTAAxZkZYTNxQADFiSlhI4EwAMWZGWFDYUAA0FAAAAAAAAAAAAAA==
New packet:
nuyG8FlUsTveM+St8POqXH6aexiZ6LyJtFZb/g==
As you can see… much shorter! And not only that, when I use the Send Packet service, it does not work for the new packet, but it DOES work for the old one!
It’s almost like they’re in a different ‘language’ (base?)
So something’s not right… any ideas?
Thanks!!
Hi @Vince_Email ,
Any luck solving this issue?
